.github/workflows | ||
build | ||
templates | ||
Vagrant | ||
.gitignore | ||
.perltidy | ||
.travis.yml | ||
basic_passwords.txt | ||
CODE_OF_CONDUCT.md | ||
CONTRIBUTING.md | ||
INTERNALS.md | ||
LICENSE | ||
mtlogo.png | ||
mysqltuner.pl | ||
mysqltuner.png | ||
README.fr.md | ||
README.it.md | ||
README.md | ||
README.ru.md | ||
renovate.json | ||
template_example.tpl | ||
USAGE.md | ||
vulnerabilities.csv |
MySQL 5.7 (full support)
MariaDB 10.6 (full support)
MariaDB 10.5 (full support)
MariaDB 10.4 (full support)
MariaDB 10.3 (full support)
RockDB
Archive
Spider
ColummStore
TokuDB
XtraDB
Connect
*** MINIMAL REQUIREMENTS ***
Hi directadmin user!
We detected that you run mysqltuner with da_admin's credentials taken from /usr/local/directadmin/conf/my.cnf
, which might bring to a password discovery!
git clone
orgit clone --depth 1 -b master
followed by the cloning URL above.
After which, ~/.mylogin.cnf
will be created with the appropriate access.
Yes! brew install mysqltuner
- Fedora Core 30 / Docker
- Fork this Github project
- Make a new branch
- Make your changes
- Push it back to your repo
