MySQLTuner-perl/README.md
Jean-Marie Renouard 75ffa2d97d Add sponsor button
2023-02-02 08:09:19 +01:00
20 KiB
==== Build Status - Master Project Status Project Status Average time to resolve an issue Percentage of open issues GPL License
  • MariaDB 10.6 (full support)
*** MINIMAL REQUIREMENTS ***
