4.5 KiB
- MySQL 5.7 (partial support)
- MySQL 5.6 (full support)
- MariaDB 10.0 (full support)
- MySQL 5.5 (full support)
- MySQL 5.1 (full support)
* OS and OS version
* Exact MySQL version
* The full text of the error
