23 KiB
MySQL 5.7 (full support)
MariaDB 10.11 (full support)
MariaDB 10.10 (full support)
MariaDB 10.9 (full support)
MariaDB 10.8 (full support)
MariaDB 10.7 (full support)
MariaDB 10.6 (full support)
MariaDB 10.5 (full support)
MariaDB 10.4 (full support)
MariaDB 10.3 (full support)
RockDB
Archive
Spider
ColummStore
TokuDB
XtraDB
Connect
Hi directadmin user!
We detected that you run mysqltuner with da_admin's credentials taken from /usr/local/directadmin/conf/my.cnf
, which might bring to a password discovery!
git clone
orgit clone --depth 1 -b master
followed by the cloning URL above.
Important: Text::Template module is mandatory for --reportfile
and/or --template
options, because this module is needed to generate appropriate output based on a text template.
- A MySQL server installation
After which, ~/.mylogin.cnf
will be created with the appropriate access.
Yes! brew install mysqltuner
- Fedora Core 30 / Docker
- Fork this Github project
- Make a new branch
- Make your changes
- Push it back to your repo
