| images | ||
Authentik and Traefik
Overview
Additionally, I am NOT allowing Authentik to view the Docker socket and auto create providers.
Lastly, @deathnmind (https://github.com/deathnmind) and I wrote this for mkdocs. That means the ???+ you see thorughout this document are meant to be collapsible admonitions (https://squidfunk.github.io/mkdocs-material/reference/admonitions/#collapsible-blocks). I'll look at making this something nicer for GitHub soon.
DNS Record
Ensure that a DNS record exists for authentik.domain.tld as the compose and all material here assumes that will be the record name.
???+ info "authentik.io"
???+ info I am using "fake" docker secrets and binding them into the compose instead of saving sensitive data in environment variables. You can remove the secrets section and work with regular environment variables if that makes more sense for your environment. This is strictly a working example, hopefully with enough documentation to help anyone else that might be stuck.
First create an environment variable file .env in the same directory as the docker-compose.yml with the following information, ensuring to update everywhere that has a CHANGEME to match your environment. If you want, these values can all be manually coded into the docker-compose.yml instead of having a separate file.
# .env (in ALL)
DOCKERDIR=/ssd/compose # CHANGEME
PUID=1100 # CHANGEME
PGID=1100 # CHANGEME
TZ=America/New_York
DOMAIN=CHANGEME.net # CHANGEME
# PostgreSQL
POSTGRES_DB=/run/secrets/authentik_postgresql_db
POSTGRES_USER=/run/secrets/authentik_postgresql_user
POSTGRES_PASSWORD=/run/secrets/authentik_postgresql_password
# Authentik
AUTHENTIK_REDIS__HOST=redis
AUTHENTIK_POSTGRESQL__HOST=postgresql
AUTHENTIK_POSTGRESQL__NAME=$POSTGRES_DB
AUTHENTIK_POSTGRESQL__USER=$POSTGRES_USER
AUTHENTIK_POSTGRESQL__PASSWORD=$POSTGRES_PASSWORD
AUTHENTIK_ERROR_REPORTING__ENABLED: "false"
AUTHENTIK_SECRET_KEY=/run/secrets/authentik_secret_key
AUTHENTIK_COOKIE_DOMAIN=$DOMAIN
# WORKERS=2
# SMTP Host Emails are sent to
AUTHENTIK_EMAIL__PORT=587
# Optionally authenticate (don't add quotation marks to your password)
AUTHENTIK_EMAIL__USERNAME=CHANGEME@gmail.com
AUTHENTIK_EMAIL__PASSWORD=/run/secrets/authelia_notifier_smtp_password
# Use StartTLS
# Use SSL
AUTHENTIK_EMAIL__TIMEOUT=10
# Email address authentik will send from, should have a correct @domain
AUTHENTIK_EMAIL__FROM=CHANGEME@gmail.com
# GeoIP
GEOIPUPDATE_ACCOUNT_ID=CHANGEME
GEOIPUPDATE_LICENSE_KEY=CHANGEME
AUTHENTIK_AUTHENTIK__GEOIP=/geoip/GeoLite2-City.mmdb
GEOIPUPDATE_EDITION_IDS=GeoLite2-City
GEOIPUPDATE_FREQUENCY=8
version: "3.9"
# Services
postgresql:
image: postgres:12-alpine
container_name: authentik_postgres
healthcheck:
start_period: 20s
interval: 30s
retries: 5
timeout: 5s
- traefik
- "$DOCKERDIR/apps/authentik/postgresql/data:/var/lib/postgresql/data"
- POSTGRES_DB
- POSTGRES_USER
- POSTGRES_PASSWORD
secrets:
- authentik_postgresql_db
- authentik_postgresql_user
- authentik_postgresql_password
redis:
image: redis:alpine
container_name: authentik_redis
healthcheck:
start_period: 20s
interval: 30s
retries: 5
timeout: 3s
- traefik
# Use the embedded outpost (2021.8.1+) instead of the seperate Forward Auth / Proxy Provider container
authentik_server:
image: ghcr.io/goauthentik/server:latest
container_name: authentik_server
command: server
- traefik
- "$DOCKERDIR/apps/authentik/media:/media"
- "$DOCKERDIR/apps/authentik/custom-templates:/templates"
- "$DOCKERDIR/apps/authentik/geoip/data:/geoip"
- AUTHENTIK_REDIS__HOST
- AUTHENTIK_POSTGRESQL__HOST
- AUTHENTIK_POSTGRESQL__NAME
- AUTHENTIK_POSTGRESQL__USER
- AUTHENTIK_POSTGRESQL__PASSWORD
- AUTHENTIK_EMAIL__PASSWORD
- AUTHENTIK_ERROR_REPORTING__ENABLED
- AUTHENTIK_SECRET_KEY
- AUTHENTIK_COOKIE_DOMAIN
# - WORKERS
secrets:
- authelia_notifier_smtp_password
- authentik_secret_key
labels:
- "traefik.enable=true"
## HTTP Routers
- "traefik.http.routers.authentik-rtr.rule=Host(`authentik.$DOMAIN`)"
- "traefik.http.routers.authentik-rtr.entrypoints=websecure"
- "traefik.http.routers.authentik-rtr.tls=true"
- "traefik.http.routers.authentik-rtr.tls.certresolver=le"
- "traefik.http.routers.authentik-rtr-outpost.rule=HostRegexp(`{subdomain:[a-z0-9-]+}.$DOMAIN`) && PathPrefix(`/outpost.goauthentik.io/`)"
- "traefik.http.routers.authentik-rtr-outpost.entrypoints=websecure"
- "traefik.http.routers.authentik-rtr-outpost.tls=true"
- "traefik.http.routers.authentik-rtr-outpost.tls.certresolver=le"
## HTTP Services
- "traefik.http.routers.authentik-rtr.service=authentik-svc"
- "traefik.http.services.authentik-svc.loadBalancer.server.port=9000"
## Watchtower
- "com.centurylinklabs.watchtower.enable=true"
authentik_worker:
container_name: authentik_worker
command: worker
- traefik
- "$DOCKERDIR/apps/traefik/cert_export:/certs:ro"
secrets:
geoipupdate:
image: maxmindinc/geoipupdate:latest
container_name: geoipupdate
- "$DOCKERDIR/apps/authentik/geoip/data:/usr/share/GeoIP"
- GEOIPUPDATE_EDITION_IDS
- GEOIPUPDATE_FREQUENCY
- GEOIPUPDATE_ACCOUNT_ID
- GEOIPUPDATE_LICENSE_KEY
whoami-test:
image: traefik/whoami
container_name: whoami-test
security_opt:
- no-new-privileges:true
- traefik
- TZ
labels:
## HTTP Routers
- "traefik.http.routers.whoami-test-rtr.rule=Host(`whoami-test.$DOMAIN`)"
- "traefik.http.routers.whoami-test-rtr.entrypoints=websecure"
- "traefik.http.routers.whoami-test-rtr.tls=true"
- "traefik.http.routers.whoami-test-rtr.tls.certresolver=le"
## Middlewares
- "traefik.http.routers.whoami-test-rtr.middlewares=middlewares-authentik@file"
# Docker Secrets
secrets:
# Authentik Postgres
authentik_postgresql_db:
file: $DOCKERDIR/secrets/authentik_postgresql_db
authentik_postgresql_user:
file: $DOCKERDIR/secrets/authentik_postgresql_user
authentik_postgresql_password:
file: $DOCKERDIR/secrets/authentik_postgresql_password
# Authentik
authentik_secret_key:
file: $DOCKERDIR/secrets/authentik_secret_key
# GMail Auth Account
authelia_notifier_smtp_password:
file: $DOCKERDIR/secrets/authelia_notifier_smtp_password
# Networks
traefik:
external: true
Bring the authentik stack online!
Start up the container stack!
docker compose up -d
Traefik Middleware Preperation
In order to setup forwardAuth at a minimum, Traefik requires a declaration. Authentik provides an example, but in accordance with the docker-compose.yml the values below should make more sense.
???+ info "Authentik Forward Auth"
https://goauthentik.io/docs/providers/proxy/forward_auth
http:
middlewares:
middlewares-authentik:
forwardAuth:
trustForwardHeader: true
authResponseHeaders:
- X-authentik-username
- X-authentik-groups
- X-authentik-email
- X-authentik-name
- X-authentik-uid
- X-authentik-jwt
- X-authentik-meta-jwks
- X-authentik-meta-outpost
- X-authentik-meta-provider
- X-authentik-meta-app
- X-authentik-meta-version
???+ warning "Priority based on rule length"
Authentik generates the priority for authentication based on rule length (Traefik label). This means if you have a rule (Traefik label) for Authentik to listen on multiple host names with OR, || statements, it will have a higher priority than the embedded outpost. Refer to https://github.com/goauthentik/authentik/issues/2180 about setting the priority for the embedded outpost.
Once the Authentik middleware.yml with (at least) the above configuration is saved in the Traefik rules directory, validate that the middleware should be listed as enabled, via Traefik's dashboard.
- If the middleware is not listed, try
docker-compose up -d --force-recreateto recreate the containers. - The Forward Authentication WILL NOT work unless the middleware is enabled.
- Alternatively a chain of middleware can be used to enforce traefik best practices with the Authentik middleware added to the chain.
Authentik Setup
Initial Setup
- Navigate to Authentik at
https://authentik.domain.tld/if/flow/initial-setup/ - Login to Authentik to begin setup.
???+ note "First time setup"
If this is the first time logging in you will have to set the password forakadmin(default user).
NOTE: If establishing the default credentials fails - the setup is not working correctly.
After successful login to the akadmin user to Authentik open the Admin Interface clicking the button in the upper right.
You can change the username from akadmin to match whatever email scheme you previously used. In the Admin Interface go to Directory -> Users and left click on akadmin, then go to Edit:
Applications / Providers
This guide is built off of the 2022.07.03 update which includes the embedded outpost.
The embedded outpost requires version 2021.8.1 or newer. This prevents needing the seperate Forward Auth / Proxy Provider container.
Traefik Domain Wide / Catch All (forwardAuth)
Provider Creation (domain wide)
In the Admin Interface, go to Applications -> Providers -> Create
a. Name:
Domain Forward Auth Provider
b. Select:Forward auth (domain level)
c. Authentication URL:https://authentik.domain.tld???+ note "Authentication URL"
This URL should be the authentik service URL, which matches the Traefik host rule/label.After hitting Finish it will show that it's not bound to an Application:
Application Creation (domain wide)
In the Admin Interface, go to Applications -> Applications -> Create
a. Name:
Domain Forward Auth Application
This is what appears on the Authentik user interface/dashboard
b. Slug:domain-forward-auth-application
An internal application name, name isn't super important
c. Provider:Domain Forward Auth Provider
This should match the previously created provider
d. Launch URL:empty
e. UI Settings (additional) - Up to you to decide on any of the remaining optional items.After hitting Create it will show that it is now bound to the previously created provider:
Embedded Outpost (domain wide)
In the Admin Interface, go to Applications -> Outposts
Edit the existing embedded outpost by clicking Edit under Actions
Highlight any application you want the outpost to be able to provide for. In this case Highlight
Domain Forward Auth ApplicationAfter hitting Update the Outpost page will show that the embedded outpost now has a provider bound to it:
Traefik Domain Wide / Catch All (Test / Validation)
In order for Traefik to apply forwardAuth and require authentication to access a resource, you must tell Traefik that by adding a Middleware.
In the above docker-compose.yml I have a whoami container for testing. This container gives you a ton of important information for troubleshooting and debugging.
## Middlewares
middlewares-authentik@file is what was defined at the top of this document in middlewares.yml.
For each container you want protected, ensure you update/add the http router piece of Traefik's label, specifically whoami-test-rtr in the example shown above.
Once this label is added to the container, recreate it.
# Example using the whoami-test container
docker-compose up -d -force-recreate whoami-test
???+ warning "Incognito Browser"
Because authentik uses cookies, I recommend using Incognito for each piece of testing, so you don't have to clear cookies every time or when something is setup incorrectly.
**While using a container behind Authentik, it prompts for authentication, and then flashes but doesn't load. This generally indicates cookies are messing up the loading. So use INCOGNITO**.
Next, navigate to https://whoami-test.domain.tld. You should hit the authentication splash page due to Traefik's middleware. Notice that the text below gives you a little bit of information that it is being caught by the Catch All rule.
After the redirect, look at the whoami information. Notice it even reflects the domain wide forwardAuth and that it is using the embedded outpost!
X-Authentik-Meta-App: domain-forward-auth-application
Traefik Individual Application (forwardAuth)
A lot of the steps are similar to the Domain Catch-all configuration with a few changes.
???+ info "providers/proxy: no exposed urls #3151"
https://github.com/goauthentik/authentik/pull/3151
> This PR greatly simplifies the Forward auth setup for traefik and envoy. It'll remove the requirement /outpost.goauthentik.io to be openly accessible, which makes setup easier and decreases attack surface.
Provider Creation (individual application)
a. Name:
whoami-test individual auth
b. Select:Forward auth (single application)
*Single Application is where we change it up!
c. External Host:https://whoami-test.domain.tldAfter hitting Finish it will show that it's not bound to an Application:
Application Creation (individual application)
a. Name:
whoami-test individual application
b. Slug:whoami-test-forward-auth-application
c. Provider:whoami-test individual auth
d. Launch URL:https://whoami-test.domain.tld
Embedded Outpost (individual application)
Domain Forward Auth ApplicationBEFORE HIGHLIGHT
Notice that BEFORE highlighting, it still has only the domain wide (catch all) forwardAuth highlighted:
AFTER HIGHLIGHT
Traefik Individual Application (Test / Validation)
## Middlewares
Next, navigate to https://whoami-test.domain.tld. You should hit the authentication splash page due to Traefik's middleware. Notice that the text below gives you a little bit of information that it is being caught by the Individual Application rule whoami-test individual application:
After the redirect, look at the whoami information. Notice it even reflects the application specific forwardAuth and that it is using the embedded outpost!
X-Authentik-Meta-App: whoami-test-forward-auth-application
New User creation (optional)
Fill in the required information
To create an admin, click the
+in the Groups field and add the user to the "Authentik Admins" group.
On the Users screen, click the down arrow beside the new user to view the
Set passwordoption:
Logout of the current user, and login as the new user to ensure it can login and has administration privileges on the authentik WebUI.
Yubikey
???+ warning "Backup Admin/Alternate Account"
To prevent locking yourself out and having to start over by deleting your postgres database, create a backup administrator or work on a non-administrator account.
???+ info "Force MFA"
If you are unable to perform the below steps, skip to the Force Authentication section below
If in the Admin Interface, go to the User Interface via the button at the top left of the screen.
Navigate to the MFA Devices screen.
???+ danger "Credential created on token"
By performing the setup like this, it asks to create a credential on the Yubikey device itself. If you want to make it where it does NOT create the credential itself skip setup for now and go to the WebAuthn Credential Creation section where I will show how to change the save credential to key option. After changing that option, you can revisit setup.
When the key is successfully registered to your user it will show in the MFA Devices screen:
Go to the Admin Interface
Edit the
default-authentication-mfa-validationstage
The initial settings for the
default-authentication-mfa-validationstage look like this:
Change the Device Classes to what options you want you or other users to have (by default). I am only going to REMOVE static tokens.
Update the
Not configured actionto "Force the user to configure an authenticator"
The default options are:- Continue
- Deny the user access
- Force the user to configure an authenticator
After setting the "Not configured action" to "Force the user to configure an authenticator" it will unlock the
Configuration stagesoptions.- Select:
default-authenticator-totp-setup (TOP Authenticator Setup Stage) - Select:
default-authenticator-webauthn-setup (WebAuthn Authenticator Setup Stage)
- Select:
Hit Update
Open another INCOGNITO browser and navigate back to the whoami URL or authentik's URL and sign in.
WebAuthn Credential Creation options (optional)
Edit
Resident key requirement- Default: The authenticator can create and store a dedicated credential, but if it doesn't thats alright too
Unfortunately, if I try to skip the dedicated credential, I am unable to setup a Yubikey. I am going to set this option to
The authenticator should not create a dedicated credential. -
Optionally edit
User verificationdepending on your WebAuthn expertise. I am leaving it default (User verification is preferred if available, but not required). -
Optional, Authentik by default has no preference set for the Authenticator, as shown in the above picture. This can be changed to be explicitly Yubikey OR Windows Hello/TouchID. If you do not want to be prompted by Windows Hello, as shown in the Windows Hello section, then set this to
A "roaming" authenticator, like a YubiKey.
Revisit the Yubikey section and setup your key!
Windows Hello
Press ESC to continue to actual Yubikey enrollment. This only seems to happen if you have previously setup Windows Hello. If you are prompted for a PIN that you do not know, refer to the bottom of the Yubikey section for the Yubikey documentation link to address the PIN. Optionally, you can also Force it to skip Windows Hello and go straight to the Yubikey by modifying the default-authenticator-webauthn-setup, as seen in the WebAuthn Credential Creation options section above.
Changing Domain Wide Policies
The default domain (tenant) flows for all things using Authentik happen in this order:
graph LR
B --> C[Authorization];
C --> D[Login];
Authentication default
graph LR
A[Start] --> B[Username];
B --> C[Password];
C --> D{MFA Configured?};
D -->|No| F[Login];
E --> F;
Authorization defaults
Explicit
graph LR
A[Start] --> B[Consent];
B --> C[Continue];
Implicit
graph LR
A[Start] --> B[Continue];
