57 KiB
- Client management
- DNS - Control Panels
- DNS - Domain Management
- Metric & Metric Collection
- Newsletters
- Blogs
- Books
- Newsletters
See also: IT Asset Management
DNS server control panels.
MITPython
- OpenDJ - Fork of OpenDS.
GPL-3.0Perl - Bosun - Monitoring and alerting system by Stack Exchange (Source Code, Documentation)
MITGo - Cabot - Monitoring and alerts, similar to PagerDuty.
- Cacti - Web-based network monitoring and graphing tool.
Collectors only
Dashboards
Storage
BSD-2-ClauseCPHP
