awesome-sysadmin/README.md
2024-04-12 17:56:25 +02:00
71 KiB
Raw Blame History
^ back to top ^
Build automation.
  • Gradle - Another build automation system. (Source Code) Apache-2.0 Groovy/Java
^ back to top ^
Backup software.
^ back to top ^
  • EasyBuild - EasyBuild builds software and modulefiles for High Performance Computing (HPC) systems in an efficient way. (Source Code) GPL-2.0 Python
  • Environment Modules - Environment Modules provides for the dynamic modification of a user's environment via modulefiles. (Source Code) GPL-2.0 Tcl
  • Lmod - Lmod is a Lua based module system that easily handles the MODULEPATH Hierarchical problem. (Source Code) MIT Lua
  • Spack - A flexible package manager that supports multiple versions, configurations, platforms, and compilers. (Source Code) MIT/Apache-2.0 Python
^ back to top ^
_See also: /r/chatops*
  • Errbot - Plugin based chatbot designed to be easily deployable, extensible and maintainable. (Source Code) GPL-3.0 Python
^ back to top ^
^ back to top ^
Configuration Management
^ back to top ^
  • Ansible - Provisioning, configuration management, and application-deployment tool. (Source Code) GPL-3.0 Python
  • CFEngine - Configuration management system for automated configuration and maintenance of large-scale computer systems. (Source Code) GPL-3.0 C
  • Chef - Configuration management tool using a pure-Ruby, domain-specific language (DSL) for writing system configuration "recipes". (Source Code) Apache-2.0 Ruby
  • Puppet - Software configuration management tool which includes its own declarative language to describe system configuration. (Source Code) Apache-2.0 Ruby/C
  • Rudder - Scalable and dynamic configuration management system for patching, security & compliance, based on CFEngine. (Source Code) GPL-3.0 Scala
  • Salt - Event-driven IT automation, remote task execution, and configuration management software. (Source Code) Apache-2.0 Python
^ back to top ^
Related: IT Asset Management
  • Collins - At Tumblr, it's the infrastructure source of truth and knowledge. (Source Code) Apache-2.0 Docker/Scala
  • i-doit - IT Documentation and CMDB. AGPL-3.0 PHP
  • iTop - Complete ITIL web based service management tool. (Source Code) AGPL-3.0 PHP
  • netbox - IP address management (IPAM) and data center infrastructure management (DCIM) tool. (Demo, Source Code) Apache-2.0 Python
^ back to top ^
^ back to top ^
  • Cockpit - Web-based graphical interface for servers. (Source Code) LGPL-2.1 C
  • HestiaCP - Web server control panel (fork of VestaCP). (Demo, Source Code) GPL-3.0 PHP/Shell/Other
^ back to top ^
Deployment Automation
^ back to top ^
  • Capistrano - Deploy your application to any number of machines simultaneously, in sequence or as a rolling set via SSH (rake based). (Source Code) MIT Ruby
  • CloudSlang - Flow-based orchestration tool for managing deployed applications, with Docker capabilities. (Source Code) Apache-2.0 Java
  • CloudStack - Cloud computing software for creating, managing, and deploying infrastructure cloud services. (Source Code) Apache-2.0 Java/Python
  • Cobbler - Cobbler is a Linux installation server that allows for rapid setup of network installation environments. (Source Code) GPL-2.0 Python
  • Fabric - Python library and cli tool for streamlining the use of SSH for application deployment or systems administration tasks. (Source Code) BSD-2-Clause Python
  • Genesis - A template framework for multi-environment BOSH deployments. MIT Perl
  • Mina - Really fast deployer and server automation tool (rake based). (Source Code) MIT Ruby
  • munki - Webserver-based repository of packages and package metadata, that allows macOS administrators to manage software installs. (Source Code) Apache-2.0 Python
  • Overcast - Deploy VMs across different cloud providers, and run commands and scripts across any or all of them in parallel via SSH. (Source Code) MIT Nodejs
  • Vlad the Deployer - Deployment automation (rake based). MIT Ruby
^ back to top ^
  • Diagrams.net - A.K.A. Draw.io. Easy to use Diagram UI with a plethora of templates. (Source Code) Apache-2.0 JavaScript/Docker
  • DrawThe.Net - Javascript tool that uses a YAML-formatted input to programmatically create large, complex, and visually solid diagrams. (Source Code) MIT JavaScript
  • Mermaid - Javascript module with a unique, easy, shorthand syntax. Integrates into several other tools like Grafana. (Source Code) MIT Nodejs/Docker
Distributed Filesystems
^ back to top ^
DNS - Control Panels & Domain Management
^ back to top ^
Related: DNS - Servers
^ back to top ^
  • djbdns - A collection of DNS applications, including tinydns. (Source Code) CC0-1.0 C
^ back to top ^
Open-source code editors.
^ back to top ^
^ back to top ^
^ back to top ^
^ back to top ^
  • BounCA - A personal SSL Key / Certificate Authority web-based tool for creating self-signed certificates. (Source Code) Apache-2.0 Python
  • easy-rsa - Bash script to build and manage a PKI CA. GPL-2.0 Shell
  • Fusion Directory - Improve the Management of the services and the company directory based on OpenLDAP. (Source Code) GPL-2.0 PHP
  • Indieauth - Sign in with your domain name (using the rel-me-auth protocol). (Source Code) Apache-2.0 Ruby
  • LDAP Account Manager (LAM) - Web frontend for managing entries (e.g. users, groups, DHCP settings) stored in an LDAP directory. (Source Code) GPL-3.0 PHP
  • Libravatar - Libravatar is a service which delivers your avatar (profile picture) to other websites. (Source Code) AGPL-3.0 Python
  • Pomerium - An identity and context aware access-proxy inspired by BeyondCorp. (Source Code) Apache-2.0 Docker/Go
  • Samba - Active Directory and CIFS protocol implementation. (Source Code) GPL-3.0 C
  • Smallstep Certificates - A private certificate authority (X.509 & SSH) and related tools for secure automated certificate management. (Source Code) Apache-2.0 Go
  • ZITADEL - Cloud-native Identity & Access Management solution providing a platform for secure authentication, authorization and identity management. (Source Code) Apache-2.0 Go/Docker/K8S
^ back to top ^
IT asset management software.
  • GLPI - Information Resource-Manager with an additional Administration Interface. (Source Code) GPL-3.0 PHP
  • RackTables - Datacenter and server room asset management like document hardware assets, network addresses, space in racks, networks configuration. (Demo, Source Code) GPL-2.0 PHP
  • Ralph - Asset management, DCIM and CMDB system for large Data Centers as well as smaller LAN networks. (Demo, Source Code) Apache-2.0 Python/Docker
^ back to top ^
  • Flume - Distributed, reliable, and available service for efficiently collecting, aggregating, and moving large amounts of log data. (Source Code) Apache-2.0 Java
^ back to top ^
  • aerc - Terminal MUA with a focus on plaintext and features for developers. (Source Code) MIT Go
  • Claws Mail - Old school email client (and news reader), based on GTK+. (Source Code) GPL-3.0 C
  • ImapSync - Simple IMAP migration tool for copying mailboxes to other servers. (Source Code) NLPL Perl
  • Mutt - Small but very powerful text-based mail client. (Source Code) GPL-2.0 C
  • Sylpheed - Still developed predecessor to Claws Mail, lightweight mail client. (Source Code) GPL-2.0 C
  • Thunderbird - Free email application that's easy to set up and customize. (Source Code) MPL-2.0 C/C++
Metrics & Metric Collection
^ back to top ^
  • Beats - Single-purpose data shippers that send data from hundreds or thousands of machines and systems to Logstash or Elasticsearch. (Source Code) Apache-2.0 Go
  • Statsd - Daemon that listens for statistics like counters and timers, sent over UDP or TCP, and sends aggregates to one or more pluggable backend services. MIT Nodejs
Miscellaneous
^ back to top ^
^ back to top ^
  • Bosun - Monitoring and alerting system by Stack Exchange. (Source Code) MIT Go
  • cadvisor - Analyzes resource usage and performance characteristics of running containers. Apache-2.0 Go
  • checkmk - Comprehensive solution for monitoring of applications, servers, and networks. (Source Code) GPL-2.0 Python/PHP
  • glances - Open-source, cross-platform real-time monitoring tool with CLI and web dashboard interfaces and many exporting options. (Source Code) GPL-3.0 Python
  • Observium Community Edition - Network monitoring and management platform that provides real-time insight into network health and performance. QPL-1.0 PHP
  • openITCOCKPIT Community Edition - Monitoring Suite featuring seamless integrations with Naemon, Checkmk, Grafana and more. (Demo, Source Code) GPL-3.0 deb/Docker
  • Performance Co-Pilot - Lightweight, distributed system performance and analysis framework. (Source Code) LGPL-2.1/GPL-2.0 C
  • PHP Server Monitor - Open source tool to monitor your servers and websites. (Source Code) GPL-3.0 PHP
  • PhpSysInfo - A customizable PHP script that displays information about your system nicely. (Source Code) GPL-2.0 PHP
  • Riemann - Flexible and fast events processor allowing complex events/metrics analysis. (Source Code) EPL-1.0 Java
  • rtop - Interactive, remote system monitoring tool based on SSH. MIT Go
  • ruptime - Classic system status server. AGPL-3.0 Shell
  • Scrutiny - Web UI for hard drive S.M.A.R.T monitoring, historical trends & real-world failure thresholds. MIT Go
  • Sensu - Monitoring tool for ephemeral infrastructure and distributed applications. (Source Code) MIT Go
  • Thruk - Multibackend monitoring web interface with support for Naemon, Nagios, Icinga and Shinken. (Source Code) GPL-1.0 Perl
  • Zabbix - Enterprise-class software for monitoring of networks and applications. (Source Code) GPL-2.0 C
^ back to top ^
^ back to top ^
^ back to top ^
^ back to top ^
Remote Desktop Clients
^ back to top ^
  • Remmina - Feature-rich remote desktop application for linux and other unixes. (Source Code) GPL-2.0 C
  • Tiger VNC - High-performance, multi-platform VNC client and server. (Source Code) GPL-2.0 C++
  • X2go - X2Go is an open source remote desktop software for Linux that uses the NoMachine/NX technology protocol. (Source Code) GPL-2.0 Perl
^ back to top ^
  • OPNsense - An open source FreeBSD-based firewall and router with traffic shaping, load balancing, and virtual private network capabilities. (Source Code) BSD-2-Clause C/PHP
^ back to top ^
  • etcd - Distributed K/V-Store, authenticating via SSL PKI and a REST HTTP Api for shared configuration and service discovery. (Source Code) Apache-2.0 Go
^ back to top ^
  • LXD - Container "hypervisor" and a better UX for LXC. (Source Code) Apache-2.0 Go
^ back to top ^
^ back to top ^
Troubleshooting tools.
  • grml - Bootable Debian Live CD with powerful CLI tools. (Source Code) GPL-3.0 Shell
  • mitmproxy - A Python tool used for intercepting, viewing and modifying network traffic. Invaluable in troubleshooting certain problems. (Source Code) MIT Python
  • mtr - Network utility that combines traceroute and ping. (Source Code) GPL-2.0 C
  • perf-tools - Performance analysis tools based on Linux perf_events (aka perf) and ftrace. GPL-2.0 Shell
  • Sysdig - Capture system state and activity from a running Linux instance, then save, filter and analyze. (Source Code) Apache-2.0 Docker/Lua/C
  • Wireshark - The world's foremost network protocol analyzer. (Source Code) GPL-2.0 C
^ back to top ^
  • Darcs - Cross-platform version control system, like git, mercurial or svn but with a very different approach: focus on changes rather than snapshots. (Source Code) GPL-2.0 Haskell
  • Fossil - Distributed version control with built-in wiki and bug tracking. (Source Code) BSD-2-Clause C
  • Git - Distributed revision control and source code management (SCM) with an emphasis on speed. (Source Code) GPL-2.0 C
  • Mercurial - Distributed source control management tool. (Source Code) GPL-2.0 Python/C/Rust
  • Subversion - Client-server revision control system. (Source Code) Apache-2.0 C
^ back to top ^
  • Ganeti - Cluster virtual server management software tool built on top of KVM and Xen. (Source Code) BSD-2-Clause Python/Haskell
  • KVM - Linux kernel virtualization infrastructure. (Source Code) GPL-2.0/LGPL-2.0 C
  • OpenNebula - Build and manage enterprise clouds for virtualized services, containerized applications and serverless computing. (Source Code) Apache-2.0 C++
  • oVirt - Manages virtual machines, storage and virtual networks. (Source Code) Apache-2.0 Java
  • Packer - A tool for creating identical machine images for multiple platforms from a single source configuration. (Source Code) MPL-2.0 Go
  • Proxmox VE - Virtualization management solution. (Source Code) GPL-2.0 Perl/Shell
  • QEMU - QEMU is a generic machine emulator and virtualizer. (Source Code) LGPL-2.1 C
  • Vagrant - Tool for building complete development environments. (Source Code) BUSL-1.1 Ruby
  • VirtualBox - Virtualization product from Oracle Corporation. (Source Code) GPL-3.0/CDDL-1.0 C++
  • XCP-ng - Virtualization platform based on Xen Source and Citrix® Hypervisor (formerly XenServer). (Source Code) GPL-2.0 C
  • Xen - Virtual machine monitor for 32/64 bit Intel / AMD (IA 64) and PowerPC 970 architectures. (Source Code) GPL-2.0 C
^ back to top ^
  • Dockovpn - Out-of-the-box stateless dockerized OpenVPN server which starts in less than 2 seconds. (Source Code) GPL-2.0 Docker
  • Firezone - WireGuard based VPN Server and Firewall. (Source Code) Apache-2.0 Docker
  • Headscale - Self-hostable fork of Tailscale, cross-platform clients, simple to use, built-in (currently experimental) monitoring tools. BSD-3-Clause Go
  • Nebula - A scalable p2p VPN with a focus on performance, simplicity and security. MIT Go
  • ocserv - Cisco AnyConnect-compatible VPN server. (Source Code) GPL-2.0 C
  • OpenVPN - Uses a custom security protocol that utilizes SSL/TLS for key exchange. (Source Code) GPL-2.0 C
  • SoftEther - Multi-protocol software VPN with advanced features. (Source Code) Apache-2.0 C
  • sshuttle - Poor man's VPN. LGPL-2.1 Python
  • strongSwan - Complete IPsec implementation for Linux. (Source Code) GPL-2.0 C
  • tinc - Distributed p2p VPN. (Source Code) GPL-2.0 C
  • WireGuard - Very fast VPN based on elliptic curve and public key crypto. (Source Code) GPL-2.0 C
^ back to top ^
  • Static Web Server - A cross-platform, high-performance, and asynchronous web server for static file serving. (Source Code) Apache-2.0/MIT Rust/Docker
^ back to top ^
cc license
