<!-- DO NOT DELETE THE TEXT BELOW. Please make sure relevant boxes are checked [x] --> Thank you for taking the time to work on a PR for Awesome-Sysadmin! To ensure your PR is dealt with swiftly please check the following: - [x] Your additions are [Free software](https://en.wikipedia.org/wiki/Free_software) - [x] Software your are submitting is not your own, unless you have a healthy ecosystem with a few contributors (which aren't your sock puppet accounts). - [x] Submit one item per pull request. This eases reviewing and speeds up inclusion. - [x] Format your submission as follows, where `Demo` and `Clients` are optional. Do not add a duplicate `Source code` link if it is the same as the main link. Keep the short description under 80 characters and use [sentence case](https://en.wikipedia.org/wiki/Letter_case#Sentence_case) for it, even if the project's webpage or readme uses another capitalisation. `Demo` links should only be used for interactive demos, i.e. not video demonstrations. ``- [Name](http://homepage/) - Short description, under 250 characters, sentence case. ([Demo](http://url.to/demo), [Source Code](http://url.of/source/code), [Clients](https://url.to/list/of/related/clients-or-apps)) `License` `Language` `` - [x] Additions are inserted preserving alphabetical order. - [x] Additions are not already listed at [awesome-selfhosted](https://awesome-selfhosted.net) - [x] The `Language` tag is the main **server-side** requirement for the software. Don't include frameworks or specific dialects. - [x] You have searched the repository for any relevant [issues](https://github.com/awesome-foss/awesome-sysadmin/issues) or [PRs](https://github.com/awesome-foss/awesome-sysadmin/pulls), including closed ones. - [x] Any category you are creating has the minimum requirement of 3 items. - [x] Any software project you are adding to the list is actively maintained. - [x] The pull request title is informative, unlike "Update README.md". Suggested titles: "Add aaa to bbb" for adding software aaa to section bbb, "Remove aaa from bbb" for removing, "Fix license for aaa", etc. -------------- Please take some time to answer the following questions as best you can: <!-- Failure to answer these questions in a useful and unbiased way will result in your submission being rejected. --> - **Why is it awesome?** 1Panel offers an intuitive interface for managing and monitoring servers, with real-time metrics and alerts that help maintain system health efficiently. - **Have you used it? For how long?** Yes, for over 2 months. - **Is this in a personal or professional setup?** Personal setup - **How many devices/users/services/... do you manage with it?** Managing 12 services on 1 server - **Biggest pros/cons compared to other solutions?** **Pros:** User-friendly UI,can deploy websites , manage server resources **Cons:** Limited to Go language environment. - **Any other comments about your use case, things you've found excellent, limitations you've encountered...?** 1Panel significantly improved my server management kinda like aapanel |
- Configuration Management
- Identity Management - Single Sign-On (SSO)
- Metrics & Metric Collection
- Miscellaneous
- PaaS
- Remote Desktop Clients
Build automation.
MITRuby
Backup software.
AGPL-3.0C/C++
MIT/Apache-2.0Python
_See also: /r/chatops*
Apache-2.0Ruby/C - Rudder - Scalable and dynamic configuration management system for patching, security & compliance, based on CFEngine. (Source Code)
GPL-3.0Scala - Salt - Event-driven IT automation, remote task execution, and configuration management software. (Source Code)
Apache-2.0Python
Related: IT Asset Management
Apache-2.0Python
GPL-2.0Python - CDS - Enterprise-Grade Continuous Delivery & DevOps Automation Open Source Platform. (Source Code)
Apache-2.0Java/Ruby - Jenkins - Continuous Integration Server. (Source Code)
GPL-3.0PHP - Virtualmin - Powerful and flexible web hosting control panel for Linux and BSD systems. (Source Code)
BSD-3-ClausePerl - 1Panel - 🔥 🔥 🔥 Modern, open source Linux server operation and maintenance management panel. (Source Code)
MITGo
MITPerl - munki - Webserver-based repository of packages and package metadata, that allows macOS administrators to manage software installs. (Source Code)
Apache-2.0JavaScript/Docker - Kroki - API for generating diagrams from textual descriptions. (Source Code)
MITNodejs/Docker
BSD-3-ClauseJava
Related: DNS - Servers
MITPHP
BSD-3-ClauseC
Open-source code editors.
MITTypeScript
OLDAP-2.8C
GPL-2.0PHP - LDAP Account Manager (LAM) - Web frontend for managing entries (e.g. users, groups, DHCP settings) stored in an LDAP directory. (Source Code)
Apache-2.0Go/Docker/K8S
IT asset management software.
GPL-3.0/AGPL-3.0OVF/Python - RackTables - Datacenter and server room asset management like document hardware assets, network addresses, space in racks, networks configuration. (Demo, Source Code)
GPL-2.0PHP - Ralph - Asset management, DCIM and CMDB system for large Data Centers as well as smaller LAN networks. (Demo, Source Code)
GPL-3.0C
- aerc - Terminal MUA with a focus on plaintext and features for developers. (Source Code)
MITGo - Claws Mail - Old school email client (and news reader), based on GTK+. (Source Code)
MPL-2.0C/C++
MITGo
Miscellaneous
GPL-2.0PHP - cadvisor - Analyzes resource usage and performance characteristics of running containers.
GPL-3.0PHP/Shell - glances - Open-source, cross-platform real-time monitoring tool with CLI and web dashboard interfaces and many exporting options. (Source Code)
QPL-1.0PHP - openITCOCKPIT Community Edition - Monitoring Suite featuring seamless integrations with Naemon, Checkmk, Grafana and more. (Demo, Source Code)
GPL-3.0deb/Docker - Performance Co-Pilot - Lightweight, distributed system performance and analysis framework. (Source Code)
EPL-1.0Java - rtop - Interactive, remote system monitoring tool based on SSH.
MITGo - ruptime - Classic system status server.
MITGo - Status - Simple and lightweight system monitoring tool for small homeservers with a pleasant web interface. (Demo
GPL-1.0Perl - Wazuh - Unified XDR and SIEM protection for endpoints and cloud workloads. (Source Code)
GPL-2.0C - Zabbix - Enterprise-class software for monitoring of networks and applications. (Source Code)
GPL-2.0C
GPL-3.0PHP
PaaS
Platform-as-a-Service software allows customers to provision, instantiate, run, and manage a computing platform and one or more applications, without the complexity of building and maintaining the infrastructure typically associated with developing and launching the application. Also includes Serverless computing and Function-as-a-service (FaaS) software.
- CapRover - Build your own PaaS in a few minutes. (Demo, Source Code)
Apache-2.0Docker/Nodejs - Coolify - An open-source & self-hostable Heroku / Netlify alternative (and even more). (Source Code)
Apache-2.0Docker - Dokku - An open-source PaaS (alternative to Heroku). (Source Code)
MITDocker/Shell/Go/deb - fx - A tool to help you do Function as a Service with painless on your own servers.
MITGo - Kubero - A self-hosted Heroku PaaS alternative for Kubernetes that implements GitOps. (Demo, Source Code)
GPL-3.0K8S/Nodejs/Go - LocalStack - LocalStack is a fully functional local AWS cloud stack. This includes Lambda for serverless computation. (Source Code)
Apache-2.0Python/Docker/K8S - Nhost - Firebase Alternative with GraphQL. Get a database and backend configured and ready in minutes. (Source Code)
MITDocker/Nodejs/Go - OpenFaaS - Serverless Functions Made Simple for Docker & Kubernetes. (Source Code)
MITGo - Tau - Easily build Cloud Computing Platforms with features like Serverless WebAssembly Functions, Frontend Hosting, CI/CD, Object Storage, K/V Database, and Pub-Sub Messaging. (Source Code)
BSD-3-ClauseGo/Rust/Docker - Trusted-CGI - Lightweight self-hosted lambda/applications/cgi/serverless-functions platform.
MITGo/deb/Docker
GPL-2.0Python
See also: Cloud Native Landscape - Streaming & Messaging
BSD-3-ClauseC++ - NSQ - A realtime distributed messaging platform. (Source Code)
MPL-2.0Go - ZeroMQ - Lightweight queuing system. (Source Code)
GPL-3.0C++
GPL-2.0Perl
Apache-2.0Shell/PHP/Other
Apache-2.0Java/C++
GPL-2.0C
Troubleshooting tools.
GPL-2.0C - Sysdig - Capture system state and activity from a running Linux instance, then save, filter and analyze. (Source Code)
GPL-2.0C
Apache-2.0C
GPL-2.0C
GPL-2.0C - SoftEther - Multi-protocol software VPN with advanced features. (Source Code)
GPL-2.0C
BSD-2-ClauseC - Static Web Server - A cross-platform, high-performance, and asynchronous web server for static file serving. (Source Code)
Apache-2.0/MITRust/Docker - Traefik - HTTP reverse proxy and load balancer that makes deploying microservices easy. (Source Code)
BSD-2-ClauseC
