awesome-sysadmin/README.md
MISTER_NEGATIVE 58f6eb89b1
Update README.md
<!-- DO NOT DELETE THE TEXT BELOW. Please make sure relevant boxes are checked [x] -->
Thank you for taking the time to work on a PR for Awesome-Sysadmin!
To ensure your PR is dealt with swiftly please check the following:
- [x] Your additions are [Free software](https://en.wikipedia.org/wiki/Free_software)
- [x] Software your are submitting is not your own, unless you have a healthy ecosystem with a few contributors (which aren't your sock puppet accounts).
- [x] Submit one item per pull request. This eases reviewing and speeds up inclusion.
- [x] Format your submission as follows, where `Demo` and `Clients` are optional.
  Do not add a duplicate `Source code` link if it is the same as the main link.
  Keep the short description under 80 characters and use [sentence case](https://en.wikipedia.org/wiki/Letter_case#Sentence_case)
  for it, even if the project's webpage or readme uses another capitalisation.
  `Demo` links should only be used for interactive demos, i.e. not video demonstrations.
  ``- [Name](http://homepage/) - Short description, under 250 characters, sentence case. ([Demo](http://url.to/demo), [Source Code](http://url.of/source/code), [Clients](https://url.to/list/of/related/clients-or-apps)) `License` `Language` ``
- [x] Additions are inserted preserving alphabetical order.
- [x] Additions are not already listed at [awesome-selfhosted](https://awesome-selfhosted.net)
- [x] The `Language` tag is the main **server-side** requirement for the software. Don't include frameworks or specific dialects.
- [x] You have searched the repository for any relevant [issues](https://github.com/awesome-foss/awesome-sysadmin/issues) or [PRs](https://github.com/awesome-foss/awesome-sysadmin/pulls), including closed ones.
- [x] Any category you are creating has the minimum requirement of 3 items.
- [x] Any software project you are adding to the list is actively maintained.
- [x] The pull request title is informative, unlike "Update README.md".
  Suggested titles: "Add aaa to bbb" for adding software aaa to section bbb,
  "Remove aaa from bbb" for removing, "Fix license for aaa", etc.
Please take some time to answer the following questions as best you can:
<!-- Failure to answer these questions in a useful and unbiased way will result in your submission being rejected. -->
- **Why is it awesome?**
1Panel offers an intuitive interface for managing and monitoring servers, with real-time metrics and alerts that help maintain system health efficiently.
- **Have you used it? For how long?**
Yes, for over 2 months.
- **Is this in a personal or professional setup?**
Personal setup
- **How many devices/users/services/... do you manage with it?**
Managing 12 services on 1 server
- **Biggest pros/cons compared to other solutions?**
**Pros:** User-friendly UI,can deploy websites , manage server resources
**Cons:** Limited to Go language environment.
- **Any other comments about your use case, things you've found excellent, limitations you've encountered...?**
1Panel significantly improved my  server management kinda like aapanel
2024-06-14 20:26:01 +05:30
72 KiB
Raw Blame History
^ back to top ^
Build automation.
  • Gradle - Another build automation system. (Source Code) Apache-2.0 Groovy/Java
^ back to top ^
Backup software.
^ back to top ^
  • EasyBuild - EasyBuild builds software and modulefiles for High Performance Computing (HPC) systems in an efficient way. (Source Code) GPL-2.0 Python
  • Environment Modules - Environment Modules provides for the dynamic modification of a user's environment via modulefiles. (Source Code) GPL-2.0 Tcl
  • Lmod - Lmod is a Lua based module system that easily handles the MODULEPATH Hierarchical problem. (Source Code) MIT Lua
  • Spack - A flexible package manager that supports multiple versions, configurations, platforms, and compilers. (Source Code) MIT/Apache-2.0 Python
^ back to top ^
_See also: /r/chatops*
  • Errbot - Plugin based chatbot designed to be easily deployable, extensible and maintainable. (Source Code) GPL-3.0 Python
^ back to top ^
^ back to top ^
Configuration Management
^ back to top ^
  • Ansible - Provisioning, configuration management, and application-deployment tool. (Source Code) GPL-3.0 Python
  • CFEngine - Configuration management system for automated configuration and maintenance of large-scale computer systems. (Source Code) GPL-3.0 C
  • Chef - Configuration management tool using a pure-Ruby, domain-specific language (DSL) for writing system configuration "recipes". (Source Code) Apache-2.0 Ruby
  • Puppet - Software configuration management tool which includes its own declarative language to describe system configuration. (Source Code) Apache-2.0 Ruby/C
  • Rudder - Scalable and dynamic configuration management system for patching, security & compliance, based on CFEngine. (Source Code) GPL-3.0 Scala
  • Salt - Event-driven IT automation, remote task execution, and configuration management software. (Source Code) Apache-2.0 Python
^ back to top ^
Related: IT Asset Management
  • Collins - At Tumblr, it's the infrastructure source of truth and knowledge. (Source Code) Apache-2.0 Docker/Scala
  • i-doit - IT Documentation and CMDB. AGPL-3.0 PHP
  • iTop - Complete ITIL web based service management tool. (Source Code) AGPL-3.0 PHP
  • netbox - IP address management (IPAM) and data center infrastructure management (DCIM) tool. (Demo, Source Code) Apache-2.0 Python
^ back to top ^
^ back to top ^
  • Cockpit - Web-based graphical interface for servers. (Source Code) LGPL-2.1 C
  • HestiaCP - Web server control panel (fork of VestaCP). (Demo, Source Code) GPL-3.0 PHP/Shell/Other
  • 1Panel - 🔥 🔥 🔥 Modern, open source Linux server operation and maintenance management panel. (Source Code) MIT Go
^ back to top ^
Deployment Automation
^ back to top ^
  • Capistrano - Deploy your application to any number of machines simultaneously, in sequence or as a rolling set via SSH (rake based). (Source Code) MIT Ruby
  • CloudSlang - Flow-based orchestration tool for managing deployed applications, with Docker capabilities. (Source Code) Apache-2.0 Java
  • CloudStack - Cloud computing software for creating, managing, and deploying infrastructure cloud services. (Source Code) Apache-2.0 Java/Python
  • Cobbler - Cobbler is a Linux installation server that allows for rapid setup of network installation environments. (Source Code) GPL-2.0 Python
  • Fabric - Python library and cli tool for streamlining the use of SSH for application deployment or systems administration tasks. (Source Code) BSD-2-Clause Python
  • Genesis - A template framework for multi-environment BOSH deployments. MIT Perl
  • munki - Webserver-based repository of packages and package metadata, that allows macOS administrators to manage software installs. (Source Code) Apache-2.0 Python
  • Overcast - Deploy VMs across different cloud providers, and run commands and scripts across any or all of them in parallel via SSH. (Source Code) MIT Nodejs
^ back to top ^
  • Diagrams.net - A.K.A. Draw.io. Easy to use Diagram UI with a plethora of templates. (Source Code) Apache-2.0 JavaScript/Docker
  • Mermaid - Javascript module with a unique, easy, shorthand syntax. Integrates into several other tools like Grafana. (Source Code) MIT Nodejs/Docker
Distributed Filesystems
^ back to top ^
DNS - Control Panels & Domain Management
^ back to top ^
Related: DNS - Servers
^ back to top ^
  • djbdns - A collection of DNS applications, including tinydns. (Source Code) CC0-1.0 C
^ back to top ^
Open-source code editors.
^ back to top ^
^ back to top ^
^ back to top ^
^ back to top ^
  • BounCA - A personal SSL Key / Certificate Authority web-based tool for creating self-signed certificates. (Source Code) Apache-2.0 Python
  • easy-rsa - Bash script to build and manage a PKI CA. GPL-2.0 Shell
  • Fusion Directory - Improve the Management of the services and the company directory based on OpenLDAP. (Source Code) GPL-2.0 PHP
  • LDAP Account Manager (LAM) - Web frontend for managing entries (e.g. users, groups, DHCP settings) stored in an LDAP directory. (Source Code) GPL-3.0 PHP
  • Libravatar - Libravatar is a service which delivers your avatar (profile picture) to other websites. (Source Code) AGPL-3.0 Python
  • Pomerium - An identity and context aware access-proxy inspired by BeyondCorp. (Source Code) Apache-2.0 Docker/Go
  • Samba - Active Directory and CIFS protocol implementation. (Source Code) GPL-3.0 C
  • Smallstep Certificates - A private certificate authority (X.509 & SSH) and related tools for secure automated certificate management. (Source Code) Apache-2.0 Go
  • ZITADEL - Cloud-native Identity & Access Management solution providing a platform for secure authentication, authorization and identity management. (Source Code) Apache-2.0 Go/Docker/K8S
^ back to top ^
IT asset management software.
  • GLPI - Information Resource-Manager with an additional Administration Interface. (Source Code) GPL-3.0 PHP
  • RackTables - Datacenter and server room asset management like document hardware assets, network addresses, space in racks, networks configuration. (Demo, Source Code) GPL-2.0 PHP
  • Ralph - Asset management, DCIM and CMDB system for large Data Centers as well as smaller LAN networks. (Demo, Source Code) Apache-2.0 Python/Docker
^ back to top ^
  • Flume - Distributed, reliable, and available service for efficiently collecting, aggregating, and moving large amounts of log data. (Source Code) Apache-2.0 Java
^ back to top ^
  • aerc - Terminal MUA with a focus on plaintext and features for developers. (Source Code) MIT Go
  • Claws Mail - Old school email client (and news reader), based on GTK+. (Source Code) GPL-3.0 C
  • ImapSync - Simple IMAP migration tool for copying mailboxes to other servers. (Source Code) NLPL Perl
  • Mutt - Small but very powerful text-based mail client. (Source Code) GPL-2.0 C
  • Sylpheed - Still developed predecessor to Claws Mail, lightweight mail client. (Source Code) GPL-2.0 C
  • Thunderbird - Free email application that's easy to set up and customize. (Source Code) MPL-2.0 C/C++
Metrics & Metric Collection
^ back to top ^
  • Beats - Single-purpose data shippers that send data from hundreds or thousands of machines and systems to Logstash or Elasticsearch. (Source Code) Apache-2.0 Go
  • Statsd - Daemon that listens for statistics like counters and timers, sent over UDP or TCP, and sends aggregates to one or more pluggable backend services. MIT Nodejs
Miscellaneous
^ back to top ^
^ back to top ^
  • Bosun - Monitoring and alerting system by Stack Exchange. (Source Code) MIT Go
  • cadvisor - Analyzes resource usage and performance characteristics of running containers. Apache-2.0 Go
  • checkmk - Comprehensive solution for monitoring of applications, servers, and networks. (Source Code) GPL-2.0 Python/PHP
  • glances - Open-source, cross-platform real-time monitoring tool with CLI and web dashboard interfaces and many exporting options. (Source Code) GPL-3.0 Python
  • Observium Community Edition - Network monitoring and management platform that provides real-time insight into network health and performance. QPL-1.0 PHP
  • openITCOCKPIT Community Edition - Monitoring Suite featuring seamless integrations with Naemon, Checkmk, Grafana and more. (Demo, Source Code) GPL-3.0 deb/Docker
  • Performance Co-Pilot - Lightweight, distributed system performance and analysis framework. (Source Code) LGPL-2.1/GPL-2.0 C
  • PHP Server Monitor - Open source tool to monitor your servers and websites. (Source Code) GPL-3.0 PHP
  • PhpSysInfo - A customizable PHP script that displays information about your system nicely. (Source Code) GPL-2.0 PHP
  • Riemann - Flexible and fast events processor allowing complex events/metrics analysis. (Source Code) EPL-1.0 Java
  • rtop - Interactive, remote system monitoring tool based on SSH. MIT Go
  • ruptime - Classic system status server. AGPL-3.0 Shell
  • Scrutiny - Web UI for hard drive S.M.A.R.T monitoring, historical trends & real-world failure thresholds. MIT Go
  • Sensu - Monitoring tool for ephemeral infrastructure and distributed applications. (Source Code) MIT Go
  • Status - Simple and lightweight system monitoring tool for small homeservers with a pleasant web interface. (Demo MIT Python
  • Thruk - Multibackend monitoring web interface with support for Naemon, Nagios, Icinga and Shinken. (Source Code) GPL-1.0 Perl
  • Wazuh - Unified XDR and SIEM protection for endpoints and cloud workloads. (Source Code) GPL-2.0 C
  • Zabbix - Enterprise-class software for monitoring of networks and applications. (Source Code) GPL-2.0 C
^ back to top ^
PaaS
^ back to top ^
Platform-as-a-Service software allows customers to provision, instantiate, run, and manage a computing platform and one or more applications, without the complexity of building and maintaining the infrastructure typically associated with developing and launching the application. Also includes Serverless computing and Function-as-a-service (FaaS) software.
  • CapRover - Build your own PaaS in a few minutes. (Demo, Source Code) Apache-2.0 Docker/Nodejs
  • Coolify - An open-source & self-hostable Heroku / Netlify alternative (and even more). (Source Code) Apache-2.0 Docker
  • Dokku - An open-source PaaS (alternative to Heroku). (Source Code) MIT Docker/Shell/Go/deb
  • fx - A tool to help you do Function as a Service with painless on your own servers. MIT Go
  • Kubero - A self-hosted Heroku PaaS alternative for Kubernetes that implements GitOps. (Demo, Source Code) GPL-3.0 K8S/Nodejs/Go
  • LocalStack - LocalStack is a fully functional local AWS cloud stack. This includes Lambda for serverless computation. (Source Code) Apache-2.0 Python/Docker/K8S
  • Nhost - Firebase Alternative with GraphQL. Get a database and backend configured and ready in minutes. (Source Code) MIT Docker/Nodejs/Go
  • OpenFaaS - Serverless Functions Made Simple for Docker & Kubernetes. (Source Code) MIT Go
  • Tau - Easily build Cloud Computing Platforms with features like Serverless WebAssembly Functions, Frontend Hosting, CI/CD, Object Storage, K/V Database, and Pub-Sub Messaging. (Source Code) BSD-3-Clause Go/Rust/Docker
  • Trusted-CGI - Lightweight self-hosted lambda/applications/cgi/serverless-functions platform. MIT Go/deb/Docker
^ back to top ^
^ back to top ^
^ back to top ^
See also: Cloud Native Landscape - Streaming & Messaging
Remote Desktop Clients
^ back to top ^
  • Remmina - Feature-rich remote desktop application for linux and other unixes. (Source Code) GPL-2.0 C
  • Tiger VNC - High-performance, multi-platform VNC client and server. (Source Code) GPL-2.0 C++
  • X2go - X2Go is an open source remote desktop software for Linux that uses the NoMachine/NX technology protocol. (Source Code) GPL-2.0 Perl
^ back to top ^
  • OPNsense - An open source FreeBSD-based firewall and router with traffic shaping, load balancing, and virtual private network capabilities. (Source Code) BSD-2-Clause C/PHP
^ back to top ^
  • etcd - Distributed K/V-Store, authenticating via SSL PKI and a REST HTTP Api for shared configuration and service discovery. (Source Code) Apache-2.0 Go
^ back to top ^
  • LXD - Container "hypervisor" and a better UX for LXC. (Source Code) Apache-2.0 Go
^ back to top ^
^ back to top ^
Troubleshooting tools.
  • grml - Bootable Debian Live CD with powerful CLI tools. (Source Code) GPL-3.0 Shell
  • mitmproxy - A Python tool used for intercepting, viewing and modifying network traffic. Invaluable in troubleshooting certain problems. (Source Code) MIT Python
  • mtr - Network utility that combines traceroute and ping. (Source Code) GPL-2.0 C
  • Sysdig - Capture system state and activity from a running Linux instance, then save, filter and analyze. (Source Code) Apache-2.0 Docker/Lua/C
  • Wireshark - The world's foremost network protocol analyzer. (Source Code) GPL-2.0 C
^ back to top ^
  • Darcs - Cross-platform version control system, like git, mercurial or svn but with a very different approach: focus on changes rather than snapshots. (Source Code) GPL-2.0 Haskell
  • Fossil - Distributed version control with built-in wiki and bug tracking. (Source Code) BSD-2-Clause C
  • Git - Distributed revision control and source code management (SCM) with an emphasis on speed. (Source Code) GPL-2.0 C
  • Mercurial - Distributed source control management tool. (Source Code) GPL-2.0 Python/C/Rust
  • Subversion - Client-server revision control system. (Source Code) Apache-2.0 C
^ back to top ^
  • Ganeti - Cluster virtual server management software tool built on top of KVM and Xen. (Source Code) BSD-2-Clause Python/Haskell
  • KVM - Linux kernel virtualization infrastructure. (Source Code) GPL-2.0/LGPL-2.0 C
  • OpenNebula - Build and manage enterprise clouds for virtualized services, containerized applications and serverless computing. (Source Code) Apache-2.0 C++
  • oVirt - Manages virtual machines, storage and virtual networks. (Source Code) Apache-2.0 Java
  • Packer - A tool for creating identical machine images for multiple platforms from a single source configuration. (Source Code) MPL-2.0 Go
  • Proxmox VE - Virtualization management solution. (Source Code) GPL-2.0 Perl/Shell
  • QEMU - QEMU is a generic machine emulator and virtualizer. (Source Code) LGPL-2.1 C
  • Vagrant - Tool for building complete development environments. (Source Code) BUSL-1.1 Ruby
  • VirtualBox - Virtualization product from Oracle Corporation. (Source Code) GPL-3.0/CDDL-1.0 C++
  • XCP-ng - Virtualization platform based on Xen Source and Citrix® Hypervisor (formerly XenServer). (Source Code) GPL-2.0 C
  • Xen - Virtual machine monitor for 32/64 bit Intel / AMD (IA 64) and PowerPC 970 architectures. (Source Code) GPL-2.0 C
^ back to top ^
  • Dockovpn - Out-of-the-box stateless dockerized OpenVPN server which starts in less than 2 seconds. (Source Code) GPL-2.0 Docker
  • Firezone - WireGuard based VPN Server and Firewall. (Source Code) Apache-2.0 Docker
  • Headscale - Self-hostable fork of Tailscale, cross-platform clients, simple to use, built-in (currently experimental) monitoring tools. BSD-3-Clause Go
  • Nebula - A scalable p2p VPN with a focus on performance, simplicity and security. MIT Go
  • ocserv - Cisco AnyConnect-compatible VPN server. (Source Code) GPL-2.0 C
  • OpenVPN - Uses a custom security protocol that utilizes SSL/TLS for key exchange. (Source Code) GPL-2.0 C
  • SoftEther - Multi-protocol software VPN with advanced features. (Source Code) Apache-2.0 C
  • sshuttle - Poor man's VPN. LGPL-2.1 Python
  • strongSwan - Complete IPsec implementation for Linux. (Source Code) GPL-2.0 C
  • WireGuard - Very fast VPN based on elliptic curve and public key crypto. (Source Code) GPL-2.0 C
^ back to top ^
  • Static Web Server - A cross-platform, high-performance, and asynchronous web server for static file serving. (Source Code) Apache-2.0/MIT Rust/Docker
^ back to top ^
cc license
