56 KiB
- Client management
- DNS - Control Panels
- DNS - Domain Management
- Metric & Metric Collection
- Newsletters
- Blogs
- Books
- Newsletters
See also: IT Asset Management
Apache-2.0C#/PowerShell
GPL-3.0PHP/Shell
DNS server control panels.
MITPython
- OpenDJ - Fork of OpenDS.
- Thruk - Multibackend monitoring web interface with support for Naemon, Nagios, Icinga and Shinken. (Source Code)
Collectors only
Dashboards
Storage
GPL-3.0PHP
BSD-2-ClauseCPHP
- PiVPN - The simplest way to setup and manage a VPN, designed for Raspberry Pi.
