awesome-sysadmin/README.md
Irina 7b59187df8
Update README.md
Co-authored-by: nodiscc <nodiscc@gmail.com>
2023-11-06 08:27:54 +01:00
64 KiB
Raw Blame History
certified awesome!
^ back to top ^
  • Gradle - Another build automation system. (Source Code) Groovy/Java Apache-2.0
^ back to top ^
^ back to top ^
^ back to top ^
  • Errbot - a plugin based chatbot designed to be easily deployable, extensible and maintainable. (Source Code) GPL-3.0 Python
^ back to top ^
Related: IT Asset Management
^ back to top ^
  • Clonezilla - Partition and disk imaging/cloning program. (Source Code) GPL-2.0/Other Perl/Shell/Other
  • Fog - Cloning/imaging solution/rescue suite. (Sorce Code) GPL-3.0 PHP/Shell
^ back to top ^
  • CloudStack - Cloud computing software for creating, managing, and deploying infrastructure cloud services. (Source Code)
  • Cobbler - Cobbler is a Linux installation server that allows for rapid setup of network installation environments. (Source Code)
^ back to top ^
  • Kubernetes - Orchestration system for Docker containers - (Source Code, Documentation) Apache-2.0 Go
  • Nomad - Simple and flexible orchestrator for Docker, Podman, executables, Java, and QEMU - (Source Code, Documentation) MPL-2.0 Go
^ back to top ^
^ back to top ^
^ back to top ^
^ back to top ^
^ back to top ^
  • Cockpit - web-based graphical interface for servers. (Source Code) LGPL-2.1 C
  • VestaCP - Open-Source hosting control panel. (Source Code) GPL-3.0 PHP/Shell/Other
^ back to top ^
Deployment Automation
^ back to top ^
^ back to top ^
Distributed Filesystems
^ back to top ^
^ back to top ^
  • djbdns - A collection of DNS applications, including tinydns. (Source Code) Public Domain C
^ back to top ^
Related: DNS - Servers
^ back to top ^
  • Atom Community - A fork of atom A hackable text editor from Github.
  • Geany - GTK2 text editor.
  • VSCodium - An open source cross-platform extensible code editor based on VS Code by Microsoft removing their non-free additions.
^ back to top ^
Identity Management - LDAP
^ back to top ^
^ back to top ^
  • ZITADEL - Cloud-native Identity & Access Management solution providing a platform for secure authentication, authorization and identity management.
^ back to top ^
^ back to top ^
  • GLPI - Information Resource-Manager with an additional Administration Interface. (Source Code)
^ back to top ^
  • Flume - distributed, reliable, and available service for efficiently collecting, aggregating, and moving large amounts of log data. (Source Code) Apache-2.0 Java
^ back to top ^
^ back to top ^
  • Alerta - Distributed, scaleable and flexible monitoring system. (Source Code) Apache-2.0 Python
  • Bosun - Monitoring and alerting system by Stack Exchange (Source Code) MIT Go
  • Cabot - Monitoring and alerts, similar to PagerDuty. (Source Code) MIT Python
  • cadvisor - Analyzes resource usage and performance characteristics of running containers (Source Code) Apache-2.0 Go
  • checkmk - Comprehensive solution for monitoring of applications, servers, and networks. (Source Code) Python/PHP
  • openITCOCKPIT Community Edition - Monitoring Suite featuring seamless integrations with Naemon, Checkmk, Grafana and more. (Demo, Source Code) GPL-3.0 deb/Docker
  • PHP Server Monitor - Open source tool to monitor your servers and websites. (Source Code)
  • PhpSysInfo - A customizable PHP script that displays information about your system nicely. (Source Code)
  • pyDash - Small web-based monitoring dashboard for linux. (Source Code)
  • Riemann - Flexible and fast events processor allowing complex events/metrics analysis. (Source Code)
  • rtop - an interactive, remote system monitoring tool based on SSH. (Source Code)
  • ruptime - classic system status server (Source Code) AGPL-3.0 Shell
  • Scrutiny - Hard Drive S.M.A.R.T Monitoring, Historical Trends & Real World Failure Thresholds
  • Sensu - Monitoring tool for ephemeral infrastructure and distributed applications. (Source Code)
  • Thruk - Multibackend monitoring web interface with support for Naemon, Nagios, Icinga and Shinken. (Source Code)
  • Zabbix - Enterprise-class software for monitoring of networks and applications. (Source Code)
^ back to top ^
^ back to top ^
  • Beats - Single-purpose data shippers that send data from hundreds or thousands of machines and systems to Logstash or Elasticsearch. (Source Code) Apache-2.0
  • Statsd - Daemon that listens for statistics like counters and timers, sent over UDP or TCP, and sends aggregates to one or more pluggable backend services. Nodejs MIT
^ back to top ^
^ back to top ^
^ back to top ^
^ back to top ^
^ back to top ^
Remote Desktop Clients
^ back to top ^
  • Remmina - Feature-rich remote desktop application for linux and other unixes. (Source Code)
  • Tiger VNC - High-performance, multi-platform VNC client and server. (Source Code)
  • X2go - X2Go is an open source remote desktop software for Linux that uses the NoMachine/NX technology protocol. (Source Code)
  • OPNsense - An open source FreeBSD-based firewall and router with traffic shaping, load balancing, and virtual private network capabilities. (Source Code) BSD-2-Clause C PHP
^ back to top ^
  • etcd - distributed K/V-Store, authenticating via SSL PKI and a REST HTTP Api for shared configuration and service discovery. (Source Code) Apache-2.0 Go
^ back to top ^
  • LXD a container "hypervisor" and a better UX for LXC. (Source Code) Apache-2.0 Go
^ back to top ^
^ back to top ^
^ back to top ^
^ back to top ^
  • Dockovpn - Out-of-the-box stateless dockerized OpenVPN server which starts in less than 2 seconds.
  • Firezone - WireGuard based VPN Server and Firewall.
  • Headscale - Self-hostable fork of Tailscale, cross-platform clients, simple to use, built-in (currently experimental) monitoring tools.
  • sshuttle - Poor man's VPN.
  • tinc - Distributed p2p VPN.
^ back to top ^
cc license
