awesome-sysadmin/README.md
2016-05-07 06:14:25 +00:00
48 KiB
Raw Blame History
Backup software.
  • Brebis - A fully automated backup checker
  • Obnam - An easy, secure, snapshots-based backup program with data de-duplication.
  • Eucalyptus - Private cloud software with AWS compatibility.
  • Flynn - PaaS
Cloud Storage
  • git-annex assistant - A synchronised folder on each of your OSX and Linux computers, Android devices, removable drives, NAS appliances, and cloud services.
  • ownCloud - Provides universal access to your files via the web, your computer or your mobile devices.
  • Pydio - Pydio (formerly AjaXplorer) is a mature solution for file sharing and synchronization.
  • Seafile - Another Cloud Storage solution.
  • SparkleShare - Provides cloud storage and file synchronization services. By default, it uses Git as a storage backend.
  • Syncthing - System for private, encrypted and authenticated distribution of data.
Collaborative Software
  • Web hosting
  • DNS
  • Revision Control
  • Virtualization
    • OpenVZ Web Panel - Web panel to control your OpenVZ servers.
    • Virtkick - A simple orchestrator. Manage virtual machines or Docker containers easily.
  • Server
    • Virtualmin - Control panel for Linux based on webmin.
Deployment Automation
Distributed Filesystems
DNS
  • Geany - GTK2 text editor.
LDAP
Tools and web interfaces
  • FreeIPA - Security management solution, can manage LDAP, KRB, DNS, sudo, and more
  • Graylog2 - Pluggable Log and Event Analysis Server with Alerting options.
  • N1 - Extensible mail client.
Mail servers/webmail
See https://github.com/kickball/awesome-selfhosted#email
  • Sentry - Application monitoring, event logging and aggregation.
Metric & Metric Collection
  • Collectors only
  • Dashboards
  • Storage
  • Packages
NoSQL
NoSQL databases.
  • Column-Family
  • Document Store
  • Graph
    • Neo4j - Graph database.
  • Key-Value
RDBMS
Relational DBMS.
Security
Security tools.
  • Blackbox - Safely store secrets in Git/Mercurial. Provides tooling to automatically encrypt secrets like passwords.
  • Bro - Bro is a powerful framework for network analysis and security monitoring.
  • Denyhosts - Thwart SSH dictionary based attacks and brute force attacks.
  • Fail2Ban - Scans log files and takes action on IPs that show malicious behavior.
  • FIR - Fast Incident Response, a cybersecurity incident management platform.
  • fwknop - Protects ports via Single Packet Authorization in your firewall.
  • Glastopf - A low-interaction web application honeypot to emulate vulnerabilities and gather attack data.
  • Kippo - A medium-interaction SSH honeypot, mostly used as a standalone SSH daemon with a configurable Filesystem sandbox.
  • Linux Malware Detect - A malware scanner for Linux designed around the threats faced in shared hosted environments.
  • Nmap - Nmap is a free and open source utility for network discovery and security auditing.
  • OSSEC - OSSEC is a HIDS that performs log analysis, FIM, rootkit detection, and much more.
  • OSQuery - Query your servers status and info using a SQL like interface.
  • pfSense - Firewall and Router FreeBSD distribution.
  • Snort - Network intrusion prevention system (NIPS) and network intrusion detection system (NIDS).
  • SpamAssassin - A powerful and popular email spam filter employing a variety of detection technique.
  • SSHGuard - A software to protect services in addition to SSH, written in C
SSH
SSH tools. See https://github.com/moul/awesome-ssh
Statistics
Analytics software. See https://github.com/Kickball/awesome-selfhosted#analytics
Ticketing systems
Web-based ticketing system. See https://github.com/Kickball/awesome-selfhosted#ticketing
  • sshuttle - Poor man's VPN.
  • tinc - Distributed p2p VPN.
XMPP
See https://github.com/Kickball/awesome-selfhosted#xmpp
  • darkhttpd - Small binary web server with no dependencies serving static files and quick to set up.
Web Performance
Wiki Software
See https://github.com/Kickball/awesome-selfhosted#wikis
Resources
Debian-based distributions
RPM-based distributions
Wikis
cc license
