awesome-sysadmin/README.md
52 KiB
Raw Blame History
Backup software.
  • Eucalyptus - Private cloud software with AWS compatibility.
  • Flynn - PaaS
  • GitLab CI - Gitlab's built-in, full-featured CI/CD solution. (Source Code MIT Ruby
  • Web hosting
  • DNS
    • Pi-hole - A blackhole for Internet Advertisements with a gui for managing and monitoring
  • Revision Control: see awesome-selfhosted#project-management
  • Virtualization
  • Server
Deployment Automation
Distributed Filesystems
DNS
  • CoreDNS - Flexible DNS server written on Go.
Domains
  • Geany - GTK2 text editor.
LDAP
  • OpenDJ - Fork of OpenDS.
Tools and web interfaces
  • Hindsight - Stream processing system which may be used for log aggregation (Replaces Heka).
  • ElastiFlow - Network flow Monitoring (Netflow, sFlow and IPFIX) with the Elastic Stack.
  • SWMP - Server Web Monitor Page - A responsive, eye-pleasing Linux server statistics dashboard.(Source Code)
Metric & Metric Collection
  • Collectors only
  • Dashboards
  • Storage
  • Packages
  • GNS3 - Graphical network simulator that provides a variety of virtual appliances - (Source Code, Documentation) - GPLv3
NoSQL
NoSQL databases.
  • Column-Family
  • Document Store
  • Graph
    • Neo4j - Graph database.
  • Key-Value
RDBMS
Relational DBMS.
  • rdpwrap - RDP wrapper library allowing Remote Desktop Host support and concurrent RDP sessions on reduced functionality systems for home usage.
  • genet - Caffeinated Packet Analyzer.
  • sshuttle - Poor man's VPN.
  • tinc - Distributed p2p VPN.
Resources
Debian-based distributions
  • Dotdeb - Repository with LAMP updated packages for Debian. (discontinued)
RPM-based distributions
Wikis
cc license
