- https://dbdb.io/ is a comprehensive list of database management systems - databases can be filtered by features, license, and many other criteria on the [browse](https://dbdb.io/browse) page - there is also a [leaderboard](https://dbdb.io/stats) page that shows "top" projects - the website generator is FOSS under the Apache 2.0 license https://github.com/cmu-db/dbdb.io - people wanting to submit new databases or suggest improvements can do so at https://github.com/cmu-db/dbdb.io/issues - each database software page has extensive details about each project (e.g. https://dbdb.io/db/postgresql) - it does a better job at listing/reviewing database systems than awesome-sysadmin would ever hope to do - all projects that were listed on awesome-sysadmin are already listed there (except abandoned ones like https://github.com/awesome-foss/awesome-sysadmin/pull/436, and adminer - I'll submit a separate PR to re-add it) |
- Awesome Sysadmin
- Client Management
- DNS
- Domains
- Metric & Metric Collection
- Newsletter
- SSH: see awesome-ssh
- Resources
See also: IT Asset Management
- Web hosting
- DNS
- Server
DNS
Domains
Identity Management - LDAP
- OpenDJ - Fork of OpenDS.
GPL-3.0Perl - bolo - A Do-it-Yourself monitoring framework built to gather metrics, mine data and report on the systems in your network.
Collectors only
Dashboards
Storage
Wikis
