awesome-sysadmin/README.md
nodiscc c4496514ec
Delegate database sections to dbdb.io
- https://dbdb.io/ is a comprehensive list of database management systems
- databases can be filtered by features, license, and many other criteria on the [browse](https://dbdb.io/browse) page
- there is also a [leaderboard](https://dbdb.io/stats) page that shows "top" projects
- the website generator is FOSS under the Apache 2.0 license https://github.com/cmu-db/dbdb.io
- people wanting to submit new databases or suggest improvements can do so at https://github.com/cmu-db/dbdb.io/issues
- each database software page has extensive details about each project (e.g. https://dbdb.io/db/postgresql)
- it does a better job at listing/reviewing database systems than awesome-sysadmin would ever hope to do
- all projects that were listed on awesome-sysadmin are already listed there (except abandoned ones like https://github.com/awesome-foss/awesome-sysadmin/pull/436, and adminer - I'll submit a separate PR to re-add it)
2023-01-05 15:20:17 +00:00
54 KiB
Raw Blame History
  • Bolt - You can use Bolt to run one-off tasks, scripts to automate the provisioning and management of some nodes, you can use Bolt to move a step beyond scripts, and make them shareable.
  • Duplicati - Multiple backends, encryption, web-ui and multi-OS backup tool.
See also: IT Asset Management
  • Eucalyptus - Private cloud software with AWS compatibility.
  • Kubernetes - Orchestration system for Docker containers - (Source Code, Documentation) Apache-2.0 Go
  • Nomad - Simple and flexible orchestrator for Docker, Podman, executables, Java, and QEMU - (Source Code, Documentation) MPL-2.0 Go
  • Web hosting
  • DNS
    • Pi-hole - A blackhole for Internet Advertisements with a gui for managing and monitoring
  • Virtualization
  • Server
Deployment Automation
Distributed Filesystems
  • Minio - Minio is an open source object storage server compatible with Amazon S3 APIs. (Source Code) Apache-2.0 Go
  • Perkeep (née Camlistore) - A set of open source formats, protocols, and software for modeling, storing, searching, sharing and synchronizing data.
DNS
  • CoreDNS - Flexible DNS server written on Go.
Domains
  • DnsControl - Opinionated platform for seamlessly managing your DNS configuration across any number of DNS hosts, both in the cloud or in your own infrastructure.
  • octoDNS - Set of tools and patterns that make it easy to manage your DNS records across multiple providers.
  • Atom Community - A fork of atom A hackable text editor from Github.
  • Geany - GTK2 text editor.
  • VSCodium - An open source cross-platform extensible code editor based on VS Code by Microsoft removing their non-free additions.
Identity Management - LDAP
  • OpenDJ - Fork of OpenDS.
  • ZITADEL - Cloud-native Identity & Access Management solution providing a platform for secure authentication, authorization and identity management.
  • Hindsight - Stream processing system which may be used for log aggregation (Replaces Heka).
  • Loki - horizontally-scalable, highly-available, multi-tenant log aggregation system inspired by Prometheus.
  • Bloonix - Bloonix is a monitoring solution that helps businesses to ensure high availability and performance. GPL-3.0 Perl
  • cadvisor - Analyzes resource usage and performance characteristics of running containers (Source Code) Apache-2.0 Go
  • checkmk - Comprehensive solution for monitoring of applications, servers, and networks. (Source Code) Python/PHP
  • ElastiFlow - Network flow Monitoring (Netflow, sFlow and IPFIX) with the Elastic Stack.
  • Netdata - Distributed, real-time, performance and health monitoring for systems and applications. Runs on Linux, FreeBSD, and MacOS.
  • NetXMS - Open Source network and infrastructure monitoring and management. (Source Code)
  • Scrutiny - Hard Drive S.M.A.R.T Monitoring, Historical Trends & Real World Failure Thresholds
Metric & Metric Collection
  • Collectors only
  • Dashboards
  • Storage
  • Packages
    • VictoriaMetrics - Service monitoring system and time series database.
  • GNS3 - Graphical network simulator that provides a variety of virtual appliances - (Source Code, Documentation) - GPLv3
  • Firezone - WireGuard based VPN Server and Firewall.
  • Headscale - Self-hostable fork of Tailscale, cross-platform clients, simple to use, built-in (currently experimental) monitoring tools.
  • sshuttle - Poor man's VPN.
  • tinc - Distributed p2p VPN.
  • Apache - A robust, commercial-grade, featureful implementation of an HTTP (Web) server.
  • Traefik - Traefik is a leading modern reverse proxy and load balancer.
Wikis
cc license
