awesome-sysadmin/README.md
2017-04-20 01:38:45 +00:00
50 KiB
Raw Blame History
Backup software.
  • Brebis - A fully automated backup checker
  • Obnam - An easy, secure, snapshots-based backup program with data de-duplication.
  • Bvckup - Light, versatile and very capable data replication software.
  • Flynn - PaaS
Collaborative Software
  • Web hosting
  • DNS
  • Revision Control
  • Virtualization
  • Server
Deployment Automation
Distributed Filesystems
DNS
Domains
  • Geany - GTK2 text editor.
LDAP
  • OpenDJ - Fork of OpenDS.
Tools and web interfaces
  • OpenID - A Simple Identity layer on top of OAuth 2.0.
  • N1 - Extensible mail client.
  • SWMP - Server Web Monitor Page - A responsive, eye-pleasing Linux server statistics dashboard.
Metric & Metric Collection
  • Collectors only
  • Dashboards
  • Storage
  • Packages
NoSQL
NoSQL databases.
  • Column-Family
  • Document Store
  • Graph
    • Neo4j - Graph database.
  • Key-Value
RDBMS
Relational DBMS.
    • Docker Compose - Define and run multi-container Docker applications.
  • Otto - Development and deployment system designed as the successor to Vagrant.
  • sshuttle - Poor man's VPN.
  • tinc - Distributed p2p VPN.
Web Performance
Resources
Debian-based distributions
RPM-based distributions
Wikis
cc license
