56 KiB
- Awesome Sysadmin
- Client Management
- DNS
- Domains
- Metric & Metric Collection
- Newsletter
- NoSQL
- RDBMS
- SSH: see awesome-ssh
- Resources
- Kopia - Fast and encrypted incremental backups, compression and deduplication, CLI and GUI.
See also: IT Asset Management
- Web hosting
- DNS
- Server
DNS
Domains
LDAP
- OpenDJ - Fork of OpenDS.
Tools and web interfaces
Single Sign-On (SSO)
- KeyCloak - Open Source Identity and Access Management (Source Code)
ApacheGo - checkmk - Comprehensive solution for monitoring of applications, servers, and networks. (Source Code)
Collectors only
Dashboards
Storage
NoSQL
NoSQL databases.
- Column-Family
- Document Store
- Graph
- Key-Value
RDBMS
Relational DBMS.
Resources
Debian-based distributions
RPM-based distributions
Wikis
