awesome-sysadmin/README.md
Robert Olejnik cec25a8c5b
Update README.md
Added Defguard to Identity and VPN section.
2023-06-02 10:56:48 +02:00
60 KiB
Raw Blame History
certified awesome!
^ back to top ^
  • Gradle - Another build automation system. (Source Code) Groovy/Java Apache-2.0
^ back to top ^
  • Duplicati - Multiple backends, encryption, web-ui and multi-OS backup tool.
^ back to top ^
^ back to top ^
  • Errbot - a plugin based chatbot designed to be easily deployable, extensible and maintainable. (Source Code) GPL-3.0 Python
^ back to top ^
See also: IT Asset Management
^ back to top ^
  • Clonezilla - Partition and disk imaging/cloning program. (Source Code) GPL-2.0/Other Perl/Shell/Other
  • Fog - Cloning/imaging solution/rescue suite. (Sorce Code) GPL-3.0 PHP/Shell
^ back to top ^
  • CloudStack - Cloud computing software for creating, managing, and deploying infrastructure cloud services. (Source Code)
  • Cobbler - Cobbler is a Linux installation server that allows for rapid setup of network installation environments. (Source Code)
^ back to top ^
  • Kubernetes - Orchestration system for Docker containers - (Source Code, Documentation) Apache-2.0 Go
  • Nomad - Simple and flexible orchestrator for Docker, Podman, executables, Java, and QEMU - (Source Code, Documentation) MPL-2.0 Go
^ back to top ^
^ back to top ^
^ back to top ^
^ back to top ^
^ back to top ^
  • Cockpit - web-based graphical interface for servers. (Source Code) LGPL-2.1 C
  • VestaCP - Open-Source hosting control panel. (Source Code) GPL-3.0 PHP/Shell/Other
^ back to top ^
Deployment Automation
^ back to top ^
^ back to top ^
Distributed Filesystems
^ back to top ^
  • Minio - Minio is an open source object storage server compatible with Amazon S3 APIs. (Source Code) AGPL-3.0 Go
  • Perkeep (née Camlistore) - A set of open source formats, protocols, and software for modeling, storing, searching, sharing and synchronizing data.
^ back to top ^
  • djbdns - A collection of DNS applications, including tinydns. (Source Code) Public Domain C
  • PowerDNS Authoritative Server - Versatile nameserver which supports a large number of backends.. (Source Code) GPL-2.0 C++
DNS - Control Panels
^ back to top ^
DNS server control panels.
DNS - Domain Management
^ back to top ^
  • Designate - DNSaaS services for OpenStack. (Source Code)
  • DNSControl - Synchronize your DNS to multiple providers from a simple DSL. (Source Code) MIT Go/Docker
  • DomainMOD - Manage your domains and other internet assets in a central location. (Source Code) GPL-3.0 PHP
  • octoDNS - DNS as code - Tools for managing DNS across multiple providers. MIT Python
^ back to top ^
  • Atom Community - A fork of atom A hackable text editor from Github.
  • Geany - GTK2 text editor.
  • VSCodium - An open source cross-platform extensible code editor based on VS Code by Microsoft removing their non-free additions.
^ back to top ^
Identity Management - LDAP
^ back to top ^
^ back to top ^
  • ZITADEL - Cloud-native Identity & Access Management solution providing a platform for secure authentication, authorization and identity management.
^ back to top ^
  • Defguard - OpenID Identity Provider with OpenLDAP sync and Multi-Factor Authentication, Wireguard VPN Management, Yubikey Provisioning and more. (Source Code) Apache-2.0 Rust
^ back to top ^
  • GLPI - Information Resource-Manager with an additional Administration Interface. (Source Code)
^ back to top ^
  • Flume - distributed, reliable, and available service for efficiently collecting, aggregating, and moving large amounts of log data. (Source Code) Apache-2.0 Java
^ back to top ^
^ back to top ^
  • Alerta - Distributed, scaleable and flexible monitoring system. (Source Code) Apache-2.0 Python
  • Bosun - Monitoring and alerting system by Stack Exchange (Source Code) MIT Go
  • Cabot - Monitoring and alerts, similar to PagerDuty. (Source Code) MIT Python
  • cadvisor - Analyzes resource usage and performance characteristics of running containers (Source Code) Apache-2.0 Go
  • checkmk - Comprehensive solution for monitoring of applications, servers, and networks. (Source Code) Python/PHP
  • PHP Server Monitor - Open source tool to monitor your servers and websites. (Source Code)
  • PhpSysInfo - A customizable PHP script that displays information about your system nicely. (Source Code)
  • pyDash - Small web-based monitoring dashboard for linux. (Source Code)
  • Riemann - Flexible and fast events processor allowing complex events/metrics analysis. (Source Code)
  • rtop - an interactive, remote system monitoring tool based on SSH. (Source Code)
  • Scrutiny - Hard Drive S.M.A.R.T Monitoring, Historical Trends & Real World Failure Thresholds
  • Sensu - Monitoring tool for ephemeral infrastructure and distributed applications. (Source Code)
  • Thruk - Multibackend monitoring web interface with support for Naemon, Nagios, Icinga and Shinken. (Source Code)
  • Zabbix - Enterprise-class software for monitoring of networks and applications. (Source Code)
^ back to top ^
Metric & Metric Collection
^ back to top ^
  • Collectors only
  • Dashboards
  • Storage
  • Packages
    • VictoriaMetrics - Service monitoring system and time series database.
^ back to top ^
^ back to top ^
^ back to top ^
^ back to top ^
^ back to top ^
^ back to top ^
  • OPNsense - An open source FreeBSD-based firewall and router with traffic shaping, load balancing, and virtual private network capabilities. (Source Code) BSD-2-Clause C PHP
^ back to top ^
^ back to top ^
  • Docker Compose - Define and run multi-container Docker applications.
  • Docker Swarm - Manage cluster of Docker Engines.
  • Portainer - Simple management UI for Docker.
^ back to top ^
^ back to top ^
^ back to top ^
^ back to top ^
  • Defguard - Wireguard VPN Management with integrated OpenID Identity Provider and Multi-Factor Authentication. (Source Code) Apache-2.0 Rust
  • Dockovpn - Out-of-the-box stateless dockerized OpenVPN server which starts in less than 2 seconds.
  • Firezone - WireGuard based VPN Server and Firewall.
  • Headscale - Self-hostable fork of Tailscale, cross-platform clients, simple to use, built-in (currently experimental) monitoring tools.
  • sshuttle - Poor man's VPN.
  • tinc - Distributed p2p VPN.
^ back to top ^
cc license
