awesome-sysadmin/README.md
56 KiB
Raw Blame History
  • Bolt - You can use Bolt to run one-off tasks, scripts to automate the provisioning and management of some nodes, you can use Bolt to move a step beyond scripts, and make them shareable.
  • Duplicati - Multiple backends, encryption, web-ui and multi-OS backup tool.
  • Eucalyptus - Private cloud software with AWS compatibility.
  • Flynn - PaaS
  • CDS - Enterprise-Grade Continuous Delivery & DevOps Automation Open Source Platform (Source Code) BSD-3-Clause Go
  • GitLab CI - Gitlab's built-in, full-featured CI/CD solution. (Source Code MIT Ruby
  • Web hosting
  • DNS
    • Pi-hole - A blackhole for Internet Advertisements with a gui for managing and monitoring
  • Revision Control: see awesome-selfhosted#project-management
  • Virtualization
  • Server
Deployment Automation
Distributed Filesystems
  • Minio - Minio is an open source object storage server compatible with Amazon S3 APIs. (Source Code) Apache-2.0 Go
  • Perkeep (née Camlistore) - A set of open source formats, protocols, and software for modeling, storing, searching, sharing and synchronizing data.
DNS
  • CoreDNS - Flexible DNS server written on Go.
Domains
  • DnsControl - Opinionated platform for seamlessly managing your DNS configuration across any number of DNS hosts, both in the cloud or in your own infrastructure.
  • octoDNS - Set of tools and patterns that make it easy to manage your DNS records across multiple providers.
  • Geany - GTK2 text editor.
LDAP
  • OpenDJ - Fork of OpenDS.
Tools and web interfaces
  • SAML Jackson - A SAML SSO service designed as an OAuth 2.0 flow. Integrate SAML with just a few lines of code.
  • Hindsight - Stream processing system which may be used for log aggregation (Replaces Heka).
  • ElastiFlow - Network flow Monitoring (Netflow, sFlow and IPFIX) with the Elastic Stack.
  • Netdata - Distributed, real-time, performance and health monitoring for systems and applications. Runs on Linux, FreeBSD, and MacOS.
  • NetXMS - Open Source network and infrastructure monitoring and management. (Source Code)
  • SWMP - Server Web Monitor Page - A responsive, eye-pleasing Linux server statistics dashboard.(Source Code)
  • Statusfy - A modern status page for presenting critical service updates.
  • vigil - Microservices Status Page. Monitors a distributed infrastructure and sends alerts to Slack. Written in Rust.
  • Statping - Status page system written in Go.
  • Uptime Kuma - Self-hosted status page similar to "Uptime Robot".
  • netcheck Simple ping status system written in Java, similar to Pingdom and StatusCake.
Metric & Metric Collection
  • Collectors only
  • Dashboards
  • Storage
  • Packages
  • GNS3 - Graphical network simulator that provides a variety of virtual appliances - (Source Code, Documentation) - GPLv3
NoSQL
NoSQL databases.
  • Column-Family
  • Document Store
    • [eXist-DB] (Https://www.exist-db.org/) - Open Source XML Database
  • Graph
    • Neo4j - Graph database.
  • Key-Value
RDBMS
Relational DBMS.
  • rdpwrap - RDP wrapper library allowing Remote Desktop Host support and concurrent RDP sessions on reduced functionality systems for home usage.
  • genet - Caffeinated Packet Analyzer.
  • sshuttle - Poor man's VPN.
  • tinc - Distributed p2p VPN.
  • Apache - A robust, commercial-grade, featureful implementation of an HTTP (Web) server.
Resources
Debian-based distributions
RPM-based distributions
Wikis
cc license
