Co-authored-by: Rabenherz112 <rabenherz@theravenhub.com> Co-authored-by: nodiscc <nodiscc@gmail.com>
71 KiB
- Miscellaneous
- Metrics & Metric Collection
- Remote Desktop Clients
- Blogs
- Books
- Newsletters
Build automation.
Apache-2.0
Java
- Apache Maven - Build automation tool mainly for Java. A software project management and comprehension tool. Based on the concept of a project object model (POM), Maven can manage a project's build, reporting and documentation from a central piece of information. (Source Code)
Apache-2.0
Java
- Bazel - A fast, scalable, multi-language and extensible build system. Used by Google. (Source Code)
Apache-2.0
Java
- Bolt - You can use Bolt to run one-off tasks, scripts to automate the provisioning and management of some nodes, you can use Bolt to move a step beyond scripts, and make them shareable. (Source Code)
Apache-2.0
Ruby
- GNU Make - The most popular automation build tool for many purposes, make is a tool which controls the generation of executables and other non-source files of a program from the program's source files. (Source Code)
GPL-3.0
C
- Gradle - Another build automation system. (Source Code)
Apache-2.0
Groovy/Java
- Rake - Build automation tool similar to Make, written in and extensible in Ruby. (Source Code)
MIT
Ruby
Backup software.
MIT
C
- Backupninja - Lightweight, extensible meta-backup system, provides a centralized way to configure and coordinate many different backup utilities.
GPL-2.0
Shell
- BackupPC - High-performance, enterprise-grade system for backing up to a server's disk.. (Source Code)
GPL-3.0
Perl
- Bareos - Cross-network backup solution which preserves, archives, and recovers data from all major operating systems. (Source Code)
AGPL-3.0
C++/C
- Barman - Backup and Recovery Manager for PostgreSQL. (Source Code)
GPL-3.0
Python
- BorgBackup - Deduplicating archiver with compression and authenticated encryption. (Source Code)
BSD-3-Clause
Python
- Burp - Network backup and restore program. (Source Code)
AGPL-3.0
C
GPL-2.0
C++
- Duplicati - Backup client that securely stores encrypted, incremental, compressed backups on cloud storage services and remote file servers. (Source Code)
LGPL-2.1
C#
- Duplicity - Encrypted bandwidth-efficient backup using the rsync algorithm. (Source Code)
GPL-2.0
Python
- Proxmox Backup Server - Proxmox Backup Server is an enterprise-class, client-server backup solution thatis capable of backing up virtual machines, containers, and physical hosts. (Source Code)
GPL-3.0
Rust
- rclone - Command-line program to sync files and directories to and from different cloud storage providers.. (Source Code)
MIT
Go
- Rdiff-backup - Reverse differential backup tool, over a network or locally. (Source Code)
GPL-2.0
Python
- Restic - Easy, fast, verifiable, secure and efficient remote backup tool. (Source Code)
BSD-2-Clause
Go
- Rsnapshot - Filesystem snapshot utility based on rsync. (Source Code)
GPL-2.0
Perl
MIT
Go
- UrBackup - Client/Server Open Source Network Backup for Windows, MacOS and Linux. (Source Code)
AGPL-3.0
C/C++
GPL-2.0
Python
- Environment Modules - Environment Modules provides for the dynamic modification of a user's environment via modulefiles. (Source Code)
GPL-2.0
Tcl
- Lmod - Lmod is a Lua based module system that easily handles the MODULEPATH Hierarchical problem. (Source Code)
MIT
Lua
- Spack - A flexible package manager that supports multiple versions, configurations, platforms, and compilers. (Source Code)
MIT/Apache-2.0
Python
_See also: /r/chatops*
GPL-2.0
C
- Errbot - Plugin based chatbot designed to be easily deployable, extensible and maintainable. (Source Code)
GPL-3.0
Python
- Hubot - A customizable, life embetterment robot. (Source Code)
MIT
Nodejs
Related: IT Asset Management
Apache-2.0
Docker/Scala
AGPL-3.0
PHP
- iTop - Complete ITIL web based service management tool. (Source Code)
AGPL-3.0
PHP
- netbox - IP address management (IPAM) and data center infrastructure management (DCIM) tool. (Demo, Source Code)
Apache-2.0
Python
GPL-3.0
Python
- CFEngine - Configuration management system for automated configuration and maintenance of large-scale computer systems. (Source Code)
GPL-3.0
C
- Chef - Configuration management tool using a pure-Ruby, domain-specific language (DSL) for writing system configuration "recipes". (Source Code)
Apache-2.0
Ruby
- Puppet - Software configuration management tool which includes its own declarative language to describe system configuration. (Source Code)
Apache-2.0
Ruby/C
- Salt - Event-driven IT automation, remote task execution, and configuration management software. (Source Code)
Apache-2.0
Python
GPL-2.0
Python
- CapsuleCD - CD script for automating package/library releases (npm, cookbooks, gems, pip, jars, etc). (Source Code)
MIT
Go
- CDS - Enterprise-Grade Continuous Delivery & DevOps Automation Open Source Platform. (Source Code)
BSD-3-Clause
Go
- Concourse - Concourse is a CI tool that treats pipelines as first class objects and containerizes every step along the way. (Demo, Source Code)
Apache-2.0
Go
- drone - Drone is a Continuous Delivery platform built on Docker, written in Go. (Source Code)
Apache-2.0
Go
- Factor - Programmatically define and run workflows to connect configuration management, source code management, build, continuous integration, continuous deployment and communication tools. (Source Code)
MIT
Ruby
- GitLab CI - Gitlab's built-in, full-featured CI/CD solution. (Source Code)
MIT
Ruby
- GoCD - Continuous delivery server. (Source Code)
Apache-2.0
Java/Ruby
- GolangCI - Open Source automated code review service for Go integrated with GitHub pull requests. (Source Code)
AGPL-3.0
Go
- Jenkins - Continuous Integration Server. (Source Code)
MIT
Java
- Laminar - Fast, lightweight, simple and flexible Continuous Integration. (Source Code)
GPL-3.0
C++
- PHP Censor - Open source self-hosted continuous integration server for PHP projects.
BSD-2-Clause
PHP
- PHPCI - Free and open source continuous integration specifically designed for PHP. (Source Code)
BSD-2-Clause
PHP
- Strider - Open Source Continuous Deployment / Continuous Integration platform. (Source Code)
MIT
Nodejs
- werf - Open Source CI/CD tool for building Docker images and deploying to Kubernetes via GitOps. (Source Code)
Apache-2.0
Go
- Woodpecker - Community fork of Drone that uses Docker containers. (Source Code)
Apache-2.0
Go
MIT
Python/Shell
- Cockpit - Web-based graphical interface for servers. (Source Code)
LGPL-2.1
C
- Froxlor - Lightweight server management software with Nginx and PHP-FPM support. (Source Code)
GPL-2.0
PHP
- HestiaCP - Web server control panel (fork of VestaCP). (Demo, Source Code)
GPL-3.0
PHP/Shell/Other
- ISPConfig - Manage Linux servers directly through your browser. (Source Code)
BSD-3-Clause
PHP
- Sentora - Open-Source Web hosting control panel for Linux, BSD (fork of ZPanel). (Source Code)
GPL-3.0
PHP
- Virtualmin - Powerful and flexible web hosting control panel for Linux and BSD systems. (Source Code)
GPL-3.0
Shell/Perl/Other
- Webmin - Web-based interface for system administration for Unix. (Source Code)
BSD-3-Clause
Perl
MIT
Ruby
Apache-2.0
Java
Apache-2.0
Java/Python
GPL-2.0
Python
- Fabric - Python library and cli tool for streamlining the use of SSH for application deployment or systems administration tasks. (Source Code)
BSD-2-Clause
Python
MIT
Perl
- Mina - Really fast deployer and server automation tool (rake based). (Source Code)
MIT
Ruby
- munki - Webserver-based repository of packages and package metadata, that allows macOS administrators to manage software installs. (Source Code)
Apache-2.0
Python
- Overcast - Deploy VMs across different cloud providers, and run commands and scripts across any or all of them in parallel via SSH. (Source Code)
MIT
Nodejs
MIT
Ruby
Apache-2.0
JavaScript/Docker
- DrawThe.Net - Javascript tool that uses a YAML-formatted input to programmatically create large, complex, and visually solid diagrams. (Source Code)
MIT
JavaScript
- Kroki - API for generating diagrams from textual descriptions. (Source Code)
MIT
Java
- Mermaid - Javascript module with a unique, easy, shorthand syntax. Integrates into several other tools like Grafana. (Source Code)
MIT
Nodejs/Docker
LGPL-3.0
C++
- DRBD - Distributed replicated storage system, implemented as a Linux kernel driver. (Source Code)
GPL-2.0
C
- GlusterFS - Software-defined distributed storage that can scale to several petabytes, with interfaces for object, block and file storage. (Source Code)
GPL-2.0/LGPL-3.0
C
- Hadoop Distributed Filesystem (HDFS) - Distributed file system that provides high-throughput access to application data. (Source Code)
Apache-2.0
Java
- JuiceFS - Distributed POSIX file system built on top of Redis and S3. (Source Code)
Apache-2.0
Go
- Kubo - Implementation of IPFS, a global, versioned, peer-to-peer filesystem that seeks to connect all computing devices with the same system of files.
Apache-2.0/MIT
Go
- LeoFS - Highly available, distributed, replicated eventually consistent object/blob store. (Source Code)
Apache-2.0
Erlang
- Lustre - Parallel distributed file system, generally used for large-scale cluster computing. (Source Code)
GPL-2.0
C
- Minio - High-performance, S3 compatible object store built for large scale AI/ML, data lake and database workloads. (Source Code)
AGPL-3.0
Go
- MooseFS - Fault tolerant, network distributed file system. (Source Code)
GPL-2.0
C
- OpenAFS - Distributed network file system with read-only replicas and multi-OS support. (Source Code)
IPL-1.0
C
- Openstack Swift - A highly available, distributed, eventually consistent object/blob store. (Source Code)
Apache-2.0
Python
- Perkeep - A set of open source formats, protocols, and software for modeling, storing, searching, sharing and synchronizing data (previously Camlistore). (Source Code)
Apache-2.0
C
- TahoeLAFS - Secure, decentralized, fault-tolerant, peer-to-peer distributed data store and distributed file system. (Source Code)
GPL-2.0
Python
- XtreemFS - Distributed, replicated and fault-tolerant file system for federated IT infrastructures.. (Source Code)
BSD-3-Clause
Java
MPL-2.0
C
- CoreDNS - Flexible DNS server. (Source Code)
Apache-2.0
Go
- djbdns - A collection of DNS applications, including tinydns. (Source Code)
CC0-1.0
C
- dnsmasq - Provides network infrastructure for small networks: DNS, DHCP, router advertisement and network boot. (Source Code)
GPL-2.0
C
- Knot - High performance authoritative-only DNS server. (Source Code)
GPL-3.0
C
- NSD - Authoritative DNS name server developed speed, reliability, stability and security. (Source Code)
BSD-3-Clause
C
- PowerDNS Authoritative Server - Versatile nameserver which supports a large number of backends. (Source Code)
GPL-2.0
C++
- Unbound - Validating, recursive, and caching DNS resolver. (Source Code)
BSD-3-Clause
C
- Yadifa - Clean, small, light and RFC-compliant name server implementation developed from scratch by .eu. (Source Code)
BSD-3-Clause
C
Related: DNS - Servers
ISC
Perl
Apache-2.0
Python
MIT
Go/Docker
- DomainMOD - Manage your domains and other internet assets in a central location. (Source Code)
GPL-3.0
PHP
- nsupdate.info - Dynamic DNS service. (Demo, Source Code)
BSD-3-Clause
Python
- octoDNS - DNS as code - Tools for managing DNS across multiple providers.
MIT
Python
- Poweradmin - Web-based DNS control panel for PowerDNS server. (Source Code)
GPL-3.0
PHP
- SPF Toolbox - Application to look up DNS records such as SPF, MX, Whois, and more. (Source Code)
MIT
PHP
Open-source code editors.
MIT
JavaScript
- Brackets - Code editor for web designers and front-end developers. (Source Code)
MIT
JavaScript
- Eclipse - IDE written in Java with an extensible plug-in system. (Source Code)
EPL-1.0
Java
- Geany - GTK2 text editor. (Source Code)
GPL-2.0
C/C++
- GNU Emacs - An extensible, customizable text editor-and more. (Source Code)
GPL-3.0
C
- Haroopad - Markdown editor with live preview. (Source Code)
GPL-3.0
JavaScript
- ICEcoder - Code editor awesomeness, built with common web languages. (Demo, Source Code)
MIT
PHP
MIT
Nodejs
- KDevelop - IDE by the people behind KDE. (Source Code)
GFDL-1.2
C++
- Micro - A modern and intuitive terminal-based text editor. (Source Code)
MIT
Go
- Nano - Easy to use, customizable text editor. (Source Code)
GPL-3.0
C
- Notepad++ - GPLv2 multi-language editor with syntax highlighting for Windows. (Source Code)
GPL-2.0
C++
- TextMate - A graphical text editor for OS X. (Source Code)
GPL-3.0
C++
- Vim - A highly configurable text editor built to enable efficient editing. (Source Code)
Vim
C
- VSCodium - An open source cross-platform extensible code editor based on VS Code by Microsoft removing their non-free additions. (Source Code)
MIT
TypeScript
GPL-3.0
C
- Apache Directory Server - Extensible and embeddable directory server, certified LDAPv3 compatible, with Kerberos 5 and Change Password Protocol support, triggers, stored procedures, queues and views. (Source Code)
Apache-2.0
Java
- FreeIPA - Integrated security information management solution combining Linux (Fedora), 389 Directory Server, Kerberos, NTP, DNS, and Dogtag Certificate System (web interface and command-line administration tools). (Source Code)
GPL-3.0
Python/C/JavaScript
- FreeRADIUS - Multi-protocol policy server (radiusd) that implements RADIUS, DHCP, BFD, and ARP and associated client/PAM library/Apache module. (Source Code)
GPL-2.0
C
- lldap - Light (simplified) LDAP implementation with a simple, intuitive web interface and GraphQL support.
GPL-3.0
Rust
- OpenLDAP - Open-source implementation of the Lightweight Directory Access Protocol (server, libraries and clients). (Source Code)
OLDAP-2.8
C
Apache-2.0
Python
- easy-rsa - Bash script to build and manage a PKI CA.
GPL-2.0
Shell
- Fusion Directory - Improve the Management of the services and the company directory based on OpenLDAP. (Source Code)
GPL-2.0
PHP
- Indieauth - Sign in with your domain name (using the rel-me-auth protocol). (Source Code)
Apache-2.0
Ruby
- LDAP Account Manager (LAM) - Web frontend for managing entries (e.g. users, groups, DHCP settings) stored in an LDAP directory. (Source Code)
GPL-3.0
PHP
- Libravatar - Libravatar is a service which delivers your avatar (profile picture) to other websites. (Source Code)
AGPL-3.0
Python
- Pomerium - An identity and context aware access-proxy inspired by BeyondCorp. (Source Code)
Apache-2.0
Docker/Go
- Samba - Active Directory and CIFS protocol implementation. (Source Code)
GPL-3.0
C
- Smallstep Certificates - A private certificate authority (X.509 & SSH) and related tools for secure automated certificate management. (Source Code)
Apache-2.0
Go
- ZITADEL - Cloud-native Identity & Access Management solution providing a platform for secure authentication, authorization and identity management. (Source Code)
Apache-2.0
Go/Docker/K8S
Apache-2.0
Go
- Authentik - Flexible identity provider with support for different protocols. (OAuth 2.0, SAML, LDAP and Radius). (Source Code)
MIT
Python
Apache-2.0
Java
IT asset management software.
GPL-3.0
PHP
GPL-2.0
PHP/Perl
- OPSI - Hardware and software inventory, client management, deployment, and patching for Linux and Windows. (Source Code)
GPL-3.0/AGPL-3.0
OVF/Python
- RackTables - Datacenter and server room asset management like document hardware assets, network addresses, space in racks, networks configuration. (Source Code, Demo)
GPL-2.0
PHP
- Ralph - Asset management, DCIM and CMDB system for large Data Centers as well as smaller LAN networks. (Source Code, Demo)
Apache-2.0
Python/Docker
- Snipe IT - Asset & license management software. (Source Code)
AGPL-3.0
PHP
Apache-2.0
Ruby
- Flume - Distributed, reliable, and available service for efficiently collecting, aggregating, and moving large amounts of log data. (Source Code)
Apache-2.0
Java
MIT
C
- Loki - Log aggregation system designed to store and query logs from all your applications and infrastructure. (Source Code)
AGPL-3.0
Go
- rsyslog - Rocket-fast system for log processing. (Source Code)
GPL-3.0
C
GPL-3.0
C
- ImapSync - Simple IMAP migration tool for copying mailboxes to other servers. (Source Code)
NLPL
Perl
GPL-2.0
C
- Sylpheed - Still developed predecessor to Claws Mail, lightweight mail client. (Source Code)
GPL-2.0
C
MPL-2.0
C/C++
Miscellaneous
Apache-2.0
C#/PowerShell
GPL-2.0
Perl/Shell/Other
GPL-2.0
Perl
- Fog - Cloning/imaging solution/rescue suite. (Source Code)
GPL-3.0
PHP/Shell
- phpList - Newsletter and email marketing software. (Source Code)
AGPL-3.0
PHP
AGPL-3.0
Docker/Python
- Alerta - Distributed, scalable and flexible monitoring system. (Source Code)
Apache-2.0
Python
- Bloonix - Bloonix is a monitoring solution that helps businesses to ensure high availability and performance. (Source Code)
GPL-3.0
Perl
- Bosun - Monitoring and alerting system by Stack Exchange. (Source Code)
MIT
Go
- Cacti - Web-based network monitoring and graphing tool. (Source Code)
GPL-2.0
PHP
- cadvisor - Analyzes resource usage and performance characteristics of running containers. (Source Code)
Apache-2.0
Go
- checkmk - Comprehensive solution for monitoring of applications, servers, and networks. (Source Code)
GPL-2.0
Python/PHP
- dashdot - A simple, modern server dashboard for smaller private servers. (Demo)
MIT
Nodejs/Docker
MIT
Java
- eZ Server Monitor - A lightweight and simple dashboard monitor for Linux, available in Web and Bash application. (Source Code)
GPL-3.0
PHP/Shell
- glances - Open-source, cross-platform real-time monitoring tool with CLI and web dashboard interfaces and many exporting options. (Source Code))
GPL-3.0
Python
- Healthchecks - Monitoring for cron jobs, background services and scheduled tasks. (Source Code)
BSD-3-Clause
Python
- Icinga - Nagios fork that has since lapped nagios several times. Comes with the possibility of clustered monitoring. (Source Code)
GPL-2.0
C++
- LibreNMS - Fully featured network monitoring system that provides a wealth of features and device support. (Source Code)
GPL-3.0
PHP
- Linux Dash - A low-overhead monitoring web dashboard for a GNU/Linux machine.
MIT
Nodejs/Go/Python/PHP
- Monit - Small utility for managing and monitoring Unix systems. (Source Code)
AGPL-3.0
C
- Munin - Networked resource monitoring tool. (Source Code)
GPL-2.0
Perl/Shell
- Naemon - Network monitoring tool based on the Nagios 4 core with performance enhancements and new features. (Source Code)
GPL-2.0
C
- Nagios - Computer system, network and infrastructure monitoring software application. (Source Code)
GPL-2.0
C
- Netdata - Distributed, real-time, performance and health monitoring for systems and applications. Runs on Linux, FreeBSD, and MacOS. (Source Code)
GPL-3.0
C
LGPL-3.0/GPL-3.0
Java/C++/C
- Observium Community Edition - Network monitoring and management platform that provides real-time insight into network health and performance.
QPL-1.0
PHP
- openITCOCKPIT Community Edition - Monitoring Suite featuring seamless integrations with Naemon, Checkmk, Grafana and more. (Demo, Source Code)
GPL-3.0
deb/Docker
- Performance Co-Pilot - Lightweight, distributed system performance and analysis framework. (Source Code)
LGPL-2.1/GPL-2.0
C
GPL-3.0
PHP
GPL-2.0
PHP
Apache-2.0
Go
EPL-1.0
Java
- rtop - Interactive, remote system monitoring tool based on SSH. (Source Code)
MIT
Go
- ruptime - Classic system status server. (Source Code)
AGPL-3.0
Shell
- Scrutiny - Web UI for hard drive S.M.A.R.T monitoring, historical trends & real-world failure thresholds.
MIT
Go
MIT
Go
MIT
Python
- Thruk - Multibackend monitoring web interface with support for Naemon, Nagios, Icinga and Shinken. (Source Code)
GPL-1.0
Perl
GPL-2.0
C
Apache-2.0
Go
- Collectd - System statistics collection daemon. (Source Code)
MIT
C
- Diamond - Daemon that collects system metrics and publishes them to Graphite (and others).
MIT
Python
- Grafana - A Graphite & InfluxDB Dashboard and Graph Editor. (Source Code)
AGPL-3.0
Go
- Graphite - Scalable graphing server. (Source Code)
Apache-2.0
Python
- RRDtool - Industry standard, high performance data logging and graphing system for time series data. (Source Code)
GPL-2.0
C
- Statsd - Daemon that listens for statistics like counters and timers, sent over UDP or TCP, and sends aggregates to one or more pluggable backend services.
MIT
Nodejs
- tcollector - Gathers data from local collectors and pushes the data to OpenTSDB. (Source Code)
LGPL-3.0/GPL-3.0
Python
- Telegraf - Plugin-driven server agent for collecting, processing, aggregating, and writing metrics.
MIT
Go
GPL-3.0
Python
- OpenWISP - Open Source Network Management System for OpenWRT based routers and access points. (Demo, Source Code)
GPL-3.0
Python
- Oxidized - Network device configuration backup tool.
Apache-2.0
Ruby
- phpIPAM - Open source IP address management with PowerDNS integration. (Source Code)
GPL-3.0
PHP
- RANCID - Monitor network devices configuration and maintain history of changes. (Source Code)
BSD-3-Clause
Perl/Shell
- rConfig - Network device configuration management tool. (Source Code)
GPL-3.0
PHP
MIT
Go
- fpm - Versatile multi format package creator. (Source Code)
MIT
Ruby
- omnibus-ruby - Easily create full-stack installers for your project across a variety of platforms.
Apache-2.0
Ruby
GPL-2.0
Python
Apache-2.0
Java
- BeanstalkD - A simple, fast work queue. (Source Code)
MIT
C
- Gearman - Fast multi-language queuing/job processing platform. (Source Code)
BSD-3-Clause
C++
- Kafka - Extremely high performance publish/subscribe message system. (Source Code)
Apache-2.0
Java
- NSQ - A realtime distributed messaging platform. (Source Code)
MPL-2.0
Go
- RabbitMQ - Robust, fully featured, cross distro queuing system. (Source Code)
MPL-2.0/Apache-2.0
Erlang
- ZeroMQ - Lightweight queuing system. (Source Code)
GPL-3.0
C++
GPL-2.0
C
GPL-2.0
C++
GPL-2.0
Perl
GPL-2.0
C
- OpenWrt - A Linux-based router featuring Mesh networking, IPS via snort and AQM among many other features. (Source Code)
GPL-2.0
C
- OPNsense - An open source FreeBSD-based firewall and router with traffic shaping, load balancing, and virtual private network capabilities. (Source Code)
BSD-2-Clause
C/PHP
- pfSense CE - Free network firewall distribution, based on the FreeBSD operating system with a custom kernel and including third party free software packages for additional functionality. (Source Code)
Apache-2.0
Shell/PHP/Other
MPL-2.0
Go
- etcd - Distributed K/V-Store, authenticating via SSL PKI and a REST HTTP Api for shared configuration and service discovery. (Source Code)
Apache-2.0
Go
- ZooKeeper - ZooKeeper is a centralized service for maintaining configuration information, naming, providing distributed synchronization, and providing group services. (Source Code)
Apache-2.0
Java/C++
Apache-2.0
Go
- Docker Swarm - Manage cluster of Docker Engines. (Source Code)
Apache-2.0
Go
- Docker - Platform for developers and sysadmins to build, ship, and run distributed applications. (Source Code)
Apache-2.0
Go
- LXC - Userspace interface for the Linux kernel containment features. (Source Code)
GPL-2.0
C
- LXD - Container "hypervisor" and a better UX for LXC. (Source Code)
Apache-2.0
Go
- OpenVZ - Container-based virtualization for Linux. (Source Code)
GPL-2.0
C
alias docker=podman
. (Source Code)Apache-2.0
Go
- Portainer Community Edition - Simple management UI for Docker. (Source Code)
Zlib
Go
GPL-2.0
C
Troubleshooting tools.
GPL-3.0
Shell
- mitmproxy - A Python tool used for intercepting, viewing and modifying network traffic. Invaluable in troubleshooting certain problems. (Source Code)
MIT
Python
- mtr - Network utility that combines traceroute and ping. (Source Code)
GPL-2.0
C
GPL-2.0
Shell
- Sysdig - Capture system state and activity from a running Linux instance, then save, filter and analyze. (Source Code)
Apache-2.0
Docker/Lua/C
- Wireshark - The world's foremost network protocol analyzer. (Source Code)
GPL-2.0
C
GPL-2.0
Haskell
- Fossil - Distributed version control with built-in wiki and bug tracking. (Source Code)
BSD-2-Clause
C
- Git - Distributed revision control and source code management (SCM) with an emphasis on speed. (Source Code)
GPL-2.0
C
- Mercurial - Distributed source control management tool. (Source Code)
GPL-2.0
Python/C/Rust
- Subversion - Client-server revision control system. (Source Code)
Apache-2.0
C
BSD-2-Clause
Python/Haskell
- KVM - Linux kernel virtualization infrastructure. (Source Code)
GPL-2.0/LGPL-2.0
C
- OpenNebula - Build and manage enterprise clouds for virtualized services, containerized applications and serverless computing. (Source Code)
Apache-2.0
C++
- oVirt - Manages virtual machines, storage and virtual networks. (Source Code)
Apache-2.0
Java
- Packer - A tool for creating identical machine images for multiple platforms from a single source configuration. (Source Code)
MPL-2.0
Go
- Proxmox VE - Virtualization management solution. (Source Code)
GPL-2.0
Perl/Shell
- QEMU - QEMU is a generic machine emulator and virtualizer. (Source Code)
LGPL-2.1
C
- Vagrant - Tool for building complete development environments. (Source Code)
BUSL-1.1
Ruby
- VirtualBox - Virtualization product from Oracle Corporation. (Source Code)
GPL-3.0/CDDL-1.0
C++
- XCP-ng - Virtualization platform based on Xen Source and Citrix® Hypervisor (formerly XenServer). (Source Code)
GPL-2.0
C
- Xen - Virtual machine monitor for 32/64 bit Intel / AMD (IA 64) and PowerPC 970 architectures. (Source Code)
GPL-2.0
C
GPL-2.0
Docker
- Firezone - WireGuard based VPN Server and Firewall. (Source Code)
Apache-2.0
Docker
BSD-3-Clause
Go
MIT
Go
- ocserv - Cisco AnyConnect-compatible VPN server. (Source Code)
GPL-2.0
C
- OpenVPN - Uses a custom security protocol that utilizes SSL/TLS for key exchange. (Source Code)
GPL-2.0
C
MIT
Shell
- SoftEther - Multi-protocol software VPN with advanced features. (Source Code)
Apache-2.0
C
LGPL-2.1
Python
- strongSwan - Complete IPsec implementation for Linux. (Source Code)
GPL-2.0
C
- tinc - Distributed p2p VPN. (Source Code)
GPL-2.0
C
- WireGuard - Very fast VPN based on elliptic curve and public key crypto. (Source Code)
GPL-2.0
C
BSD-3-Clause
Go
- Apache HTTP Server - Secure, efficient and extensible server that provides HTTP services in sync with the current HTTP standards. (Source Code)
Apache-2.0
C
- Caddy - Powerful, enterprise-ready, open source web server with automatic HTTPS. (Source Code)
Apache-2.0
Go
- HAProxy - Very fast and reliable reverse-proxy offering high availability, load balancing, and proxying for TCP and HTTP-based applications. (Source Code)
GPL-2.0
C
- Hiawatha - An advanced and secure webserver for Unix. (Source Code)
GPL-2.0
C
- Lighttpd - Secure, fast, compliant, and very flexible web server that has been optimized for high-performance environments. (Source Code)
BSD-3-Clause
C
- Nginx - HTTP and reverse proxy server, mail proxy server, and generic TCP/UDP proxy server. (Source Code)
BSD-2-Clause
C
- Traefik - HTTP reverse proxy and load balancer that makes deploying microservices easy. (Source Code)
MIT
Go/Docker
- Varnish - Web application accelerator/caching HTTP reverse proxy. (Source Code)
BSD-2-Clause
C
AGPL-3.0
- GNU Affero General Public License 3.0Apache-2.0
- Apache, Version 2.0BSD-2-Clause
- BSD 2-clause "Simplified"BSD-3-Clause
- BSD 3-Clause "New" or "Revised"BUSL-1.1
- Business Source License 1.1CC0-1.0
- Public Domain/Creative Common Zero 1.0CDDL-1.0
- Common Development and Distribution License 1.0EPL-1.0
- Eclipse Public License 1.0GFDL-1.2
- GNU Free Documentation License 1.2GPL-1.0
- GNU General Public License 1.0GPL-2.0
- GNU General Public License 2.0GPL-3.0
- GNU General Public License 3.0IPL-1.0
- IBM Public License v1.0ISC
- ISC LicenseLGPL-2.0
- GNU Lesser General Public License v2LGPL-2.1
- GNU Lesser General Public License v2.1LGPL-3.0
- GNU Lesser General Public License v3MIT
- MIT LicenseMPL-2.0
- Mozilla Public LicenseNLPL
- No Limit Public LicenseOLDAP-2.8
- Open LDAP Public License v2.8QPL-1.0
- Q Public License 1.0Vim
- Vim LicenseZlib
- zlib License
