docker-templates-unraid/README.md
2020-04-11 11:18:05 +03:00
12 KiB
Unraid A75G Templates
CyberChef
Application Name: CyberChef
Dashmachine
Application Name: Dashmachine
Default username and password
Username: admin Password: admin
Unauthorized
db-backup
Application Name: db-backup
Environment Variables
Parameter Description
ddns-route53
Before running the docker
Droppy
Application Name: Droppy
FileRun
Application Name: FileRun
Username: superuser Password: superuser
FreePBX
Application Name: FreePBX
First installation
Firefox-Syncserver
Flarum
Application Name: Flarum
Notes
Golinks
Application Name: Golinks
Gotify
Application Name: Gotify
Homer
Application Name: Homer
mkdir -p /mnt/user/appdata/homer/config/ wget -O /mnt/user/appdata/homer/config/config.yml https://raw.githubusercontent.com/bastienwirtz/homer/master/config.yml
Jitsi
Application Name: Jitsi
Change appdata location
Notes
Kiwix-serve
Application Name: Kiwix-serve
Notes
Content
Mailpile
Application Name: Mailpile
Matrix
Application Name: Matrix
Guides
Miniflux
Application Name: Miniflux
Notes
Pure-FTPd
Application Name: Pure-FTPd
Notes
Riot-web
Application Name: Riot-web
mkdir -p /mnt/user/appdata/riot-web/config wget -O /mnt/user/appdata/riot-web/config/config.json https://riot.im/develop/config.json
Wallabag
Application Name: Wallabag
PHP errors
https://github.com/wallabag/docker/issues/185
Missing texture and images
Make sure the domain variable is right http://ip:6500 and if you are hosting it http://wallabag.example.com or https://wallabag.example.com.
