Refreshed supplicant mode #44
Closed
grevelle wants to merge 59 commits from master into supplicant
grevelle commented 2021-01-09 04:34:59 +05:30 (Migrated from github.com)
I took the current master and refreshed the supplicant branch version. I updated pfatt.sh.
maxfield-allison commented 2021-03-09 19:14:41 +05:30 (Migrated from github.com)
I might be nit picking here but could you clean up the PR and recommit. Looks good from what I reviewed so far.
grevelle commented 2021-03-14 00:21:14 +05:30 (Migrated from github.com)
Given that the latest version of pfsense broke this program, I’ll wait until pfsense is patched and then verify that everything works again and touch it up.
Sent: Tuesday, March 9, 2021 7:45 AM
To: MonkWho/pfatt @.
Cc: Greg Revelle @.>; Author @.>
Subject: Re: [MonkWho/pfatt] Refreshed supplicant mode (#44)
You are receiving this because you authored the thread.
Reply to this email directly, view it on GitHubhttps://github.com/MonkWho/pfatt/pull/44#issuecomment-793917419, or unsubscribehttps://github.com/notifications/unsubscribe-auth/AHRNGQOP3AWD3M3ZMVTKAY3TCYJ4TANCNFSM4V3CL5QA.
Given that the latest version of pfsense broke this program, I’ll wait until pfsense is patched and then verify that everything works again and touch it up. From: Maxfield Allison ***@***.***> Sent: Tuesday, March 9, 2021 7:45 AM To: MonkWho/pfatt ***@***.***> Cc: Greg Revelle ***@***.***>; Author ***@***.***> Subject: Re: [MonkWho/pfatt] Refreshed supplicant mode (#44) I might be nit picking here but could you clean up the PR and recommit. Looks good from what I reviewed so far. — You are receiving this because you authored the thread. Reply to this email directly, view it on GitHub<https://github.com/MonkWho/pfatt/pull/44#issuecomment-793917419>, or unsubscribe<https://github.com/notifications/unsubscribe-auth/AHRNGQOP3AWD3M3ZMVTKAY3TCYJ4TANCNFSM4V3CL5QA>.
grevelle commented 2021-05-16 21:24:01 +05:30 (Migrated from github.com)
I made a few edits – it works with the new wpa_supplicant file.
I made a few edits – it works with the new wpa_supplicant file. From: Maxfield Allison ***@***.***> Sent: Tuesday, March 9, 2021 7:45 AM To: MonkWho/pfatt ***@***.***> Cc: Greg Revelle ***@***.***>; Author ***@***.***> Subject: Re: [MonkWho/pfatt] Refreshed supplicant mode (#44) I might be nit picking here but could you clean up the PR and recommit. Looks good from what I reviewed so far. — You are receiving this because you authored the thread. Reply to this email directly, view it on GitHub<https://github.com/MonkWho/pfatt/pull/44#issuecomment-793917419>, or unsubscribe<https://github.com/notifications/unsubscribe-auth/AHRNGQOP3AWD3M3ZMVTKAY3TCYJ4TANCNFSM4V3CL5QA>.
Pull request closed
No reviewers
No milestone
No project
No assignees
1 participant
Notifications
Due date
No due date set.
No dependencies set.
Reference: hhf/pfatt#44
No description provided.
