install | ||
maintenance | ||
monitoring | ||
optimize | ||
security | ||
master-gitlab.sh | ||
master.sh | ||
README.md |
This repository contains the master.sh
script, designed to simplify the execution of CloudPanel management and automation scripts. The master.sh
script automatically fetches a list of available scripts from the repository, allows you to select and run them, and handles dependencies and cleanup. This guide explains how to use the master.sh
script to manage your CloudPanel server efficiently.
Select any CloudPanel management script, such as backup/mysql-backup.sh
or security/ssl-renewal.sh
To use the master.sh
script on your CloudPanel server, run the following command:
- Script Categories:
- Backup Management
- SSL Certificate Management
- Site Deployment
- Database Management
- Security Updates
- Performance Optimization
- Verbose Mode: Use the
-v
flag to enable detailed logging during script execution. - Error Handling: Built-in error handling ensures that scripts exit gracefully and provide informative error messages.
The master.sh
script relies on the following tools:
sudo
: Ensures elevated permissions for installing packages and running scriptscurl
: Used to fetch the list of scripts and download individual scriptsjq
: Parses JSON responses from Forgejo API
- Self-Removal: Deletes the
master.sh
script itself - These actions ensure that your CloudPanel server remains clean after script execution
- Fork the repository
backup/
,security/
,maintenance/
) - Ensure the script follows CloudPanel best practices and includes proper error handling
chmod +x script_name.sh
) - Add appropriate documentation and usage examples
backup/
: Backup and restore scriptssecurity/
: Security-related scripts (SSL, firewall, etc.)maintenance/
: Server maintenance scriptssites/
: Website management scriptsdatabase/
: Database management scriptsmonitoring/
: Server monitoring scripts
MIT License
