| monitoring | ||
| Testing | ||
| master-forgejo.sh | ||
| master-gitlab.sh | ||
| master.sh | ||
- Script Categories:
- Backup Management
- SSL Certificate Management
- Site Deployment
- Database Management
- Security Updates
- Performance Optimization
- Verbose Mode: Use the
- Self-Removal: Deletes the
- Fork the repository
