| master-gitlab.sh | ||
| master.sh | ||
- Script Categories:
- Backup Management
- SSL Certificate Management
- Site Deployment
- Database Management
- Security Updates
- Performance Optimization
- Verbose Mode: Use the
sudo: Ensures elevated permissions for installing packages and running scriptscurl: Used to fetch the list of scripts and download individual scriptsjq: Parses JSON responses from GitHub API
- Self-Removal: Deletes the
- Fork the repository
